Efficient connectivity
With options like Gigabit Ethernet, USB 2.0, and USB host, alongside mobile printing capabilities through Apple AirPrint and Google Cloud Print, this device ensures seamless integration into any work environment. -
Advanced copying features
The Kyocera ECOSYS M6230cidn boasts automatic duplexing, ID Card Copy, and electronic sorting among other features, making it efficient for handling complex copying tasks. -
High-quality printing
Achieve crisp, clear prints with a maximum resolution of 1200 x 1200 DPI for both black and white and color documents, ensuring high-quality outputs every time. -
Robust document handling
From its 75-sheet Automatic Document Feeder (ADF) to a maximum media capacity of 1850 sheets, this device is designed to support high-volume printing and copying tasks. -
Eco-friendly technology
Leveraging Kyocera's ECOSYS technology, this printer offers long-life components that reduce waste and provide a sustainable solution to your office's printing needs.
- Kyocera ECOSYS M6230cidn - multifunction printer - colour
- Multifunction printer
- Printing Technology
- Laser (colour)
- Max Copying Speed
- Up to 30 ppm (mono) / up to 30 ppm (colour)
- Max Printing Speed
- Max Printing Resolution
- Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
- Scanning
- 600 x 600 dpi
- Display
- 7"
- Original Size
- Legal (216 x 356 mm)/A4 (210 x 297 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 75 sheets
- Media Size
- 70 x 148 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Plain paper
- Standard Media Capacity
- 350 sheets
- Max Media Capacity
- 1850 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 250 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB host
- AirPrint Enabled
- Office Machine Features
- Scan to e-mail, HyPAS (Hybrid Platform for Advanced Solutions), Kyocera ECOSYS Technology, scan to FTP, scan to SMB
- Power
- AC 230 V (50/60Hz)
- 47.5 cm x 55.8 cm x 61.6 cm
- 35.4 kg
- Environmental Standards
- ENERGY STAR Qualified
- Laser - colour
- Display Diagonal Size
- 7"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Standard Memory
- 1 GB
- Max Supported Memory
- 3 GB
- Supported Flash Memory
- SD Memory Card, SDHC Memory Card
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 999
- Exposure Control
- Automatic, manual
- Exposure Modes
- Text, photo, text and photo, map
- Copying Features
- ID Card Copy, blank page skipping, electronic sorting, Scan-once-copy-many
Printing
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PCL 5c, KPDL3, PCL 6 (XL), XPS, PRESCRIBE IIc
- First Print Out Time B/W
- 6.5 sec
- First Print Out Time Colour
- 7.5 sec
- Colour Management Features
- Mopria
Scanning
- Optical Resolution
- 600 x 600 dpi
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 75 sheets
- Min Media Size
- 70 x 148 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Plain paper
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), B6 (125 x 176 mm)
- 350 sheets
- 1850 sheets
- 100 sheets
- 250 sheets
- Input tray - 250 sheets size: A6 (105 x 148 mm) - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Bypass tray - 100 sheets size: 70 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 220 g/m² , ADF - 75 sheets size: 105 x 148 mm - Legal (216 x 356 mm) weight: 50 g/m² - 120 g/m² , Output tray - 250 sheets
- Speed Details
- Printing: up to 30 ppm (A4) - B/W , Printing: up to 30 ppm (A4) - colour , Copying: up to 30 ppm (A4) - B/W , Copying: up to 30 ppm (A4) - colour , Scanning: up to 60 ipm (A4) - B/W (300 dpi) , Scanning: up to 40 ipm (A4) - colour (300 dpi) , Printing: up to 15 ppm (A4) - duplex normal , Copying: up to 15 ppm (A4) - duplex normal , Scanning: up to 26 ipm (A4) - B/W duplex (300 dpi) , Scanning: up to 17 ipm (A4) - colour duplex (300 dpi)
- 1 x USB 2.0 - 4 pin USB Type B , 2 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
- SSL, IPsec
- Voltage Required
- 496 Watt
- Power Consumption Standby
- 70 Watt
- Power Consumption Sleep
- 0.6 Watt
- Warm-Up Time
- 26 sec
- First Copy Out Time B/W
- 8.5 sec
- First Copy Out Time Colour
- 10 sec
- TUV, ISO 9001, GS, ISO 14001, ISO 7779, ISO 9296
- ENERGY STAR Certified
- 47.5 cm
- 55.8 cm
- 61.6 cm
- 35.4 kg
Kyocera TK-5270K Black Toner | In Stock | £95.30 |
Kyocera TK-5270C Cyan Toner | In Stock | £114.01 |
Kyocera TK-5270M Magenta Toner | In Stock | £114.01 |
Kyocera TK-5270Y Yellow Toner | In Stock | £114.01 |
Kyocera Black toner Cartridge for P6230CDN | In Stock | £88.71 |
