These A4 color devices are designed specifically for small and medium-sized work groups, offering both reliability and fast output speeds in both color and b/w. The convenient touch panels provide simple, direct access to the multifunctionals' numerous functions.
- Kyocera ECOSYS M6035cidn - multifunction printer - colour
- Multifunction printer
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 100000 pages
- Max Copying Speed
- Up to 35 ppm (mono) / up to 35 ppm (colour)
- Max Printing Speed
- Max Printing Resolution
- Up to 9600 x 600 dpi (mono) / up to 9600 x 600 dpi (colour)
- Scanning
- 600 x 600 dpi
- Display
- 7"
- Original Size
- Legal (216 x 356 mm)/A4 (210 x 297 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 70 x 148 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Plain paper
- Standard Media Capacity
- 350 sheets
- Max Media Capacity
- 1850 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 250 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB host
- AirPrint Enabled
- Office Machine Features
- Scan to e-mail, scan to network, scan to FTP, scan to SMB
- Power
- AC 230 V (50/60Hz)
- 47.5 cm x 55.8 cm x 61.6 cm
- 35.4 kg
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Laser - colour
- 100000 pages
- Display Diagonal Size
- 7"
- Display Features
- Touch screen, tilt
- Interface
- AirPrint Enabled
- Standard Memory
- 1 GB
- Max Supported Memory
- 2 GB
- Supported Flash Memory
- SD Memory Card, SDHC Memory Card
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 999
- Exposure Control
- Automatic, manual
Printing
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PCL 5c, KPDL3, PCL 6 (XL), PDF 1.7, XPS
- First Print Out Time B/W
- 7 sec
- First Print Out Time Colour
- 8.5 sec
Scanning
- Optical Resolution
- 600 x 600 dpi
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 70 x 148 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Plain paper
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 70 x 148 mm
- 350 sheets
- 1850 sheets
- 100 sheets
- 250 sheets
- Input tray - 250 sheets size: A6 (105 x 148 mm) - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Bypass tray - 100 sheets size: 70 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 220 g/m² , ADF - 75 sheets size: 140 x 210 mm - Legal (216 x 356 mm) weight: 50 g/m² - 120 g/m² , Output tray - 250 sheets
- Speed Details
- Printing: up to 35 ppm (A4) - B/W , Printing: up to 35 ppm (A4) - colour , Copying: up to 35 ppm (A4) - B/W , Copying: up to 35 ppm (A4) - colour , Scanning: up to 60 ipm (A4) - B/W , Scanning: up to 40 ipm (A4) - colour
- 1 x USB 2.0 - 4 pin USB Type B , 2 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
- SSL, IPsec, 802.1x
- Operating System Support
- UNIX, Linux, Apple Mac OS X 10.5 or later, MS Windows
- Voltage Required
- 551 Watt
- Power Consumption Sleep
- 2.1 Watt
- Warm-Up Time
- 25 sec
- First Copy Out Time B/W
- 9 sec
- First Copy Out Time Colour
- 11 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 6000 pages , 1 x toner cartridge (cyan) - up to 5000 pages , 1 x toner cartridge (magenta) - up to 5000 pages , 1 x toner cartridge (yellow) - up to 5000 pages
- TUV, ISO 9001, GS, ISO 14001, ISO 7779
- ENERGY STAR Certified
- Limited warranty - 1 year
- 47.5 cm
- 55.8 cm
- 61.6 cm
- 35.4 kg
- Sound Emission
- 49.9 dBA (operating)
