Kyocera ECOSYS M5526cdn A4 Colour Laser Multifunction
Quicklinx: CHKHWS00 Mfr#: 1102R83NL0
The ECOSYS M5526cdn combines the best color quality with the lowest of costs - and it will ease your workflow significantly, too. Its dual-scan document processor, the 4.3 inch touch screen for intuitive use, and program keys to simplify complex workflows improve productivity and quality this device as an absolute all-rounder. Furthermore, this device contains a long-yield toner with a capacity of up to 3,000 pages in color - offering unrivaled low costs per page. Rest assured, it is the perfect multifunctional partner for your business and will offer you a future of brilliant colors.
  • Up to 26 pages per minute in A4 in colour and black and white
  • 1,200 dpi printing quality
  • 4,3 inch touch screen for easy operation
  • Dual scan document processor
  • Direct printing from and scanning to USB flash memory
  • High security through SSL, IPsec and Private Print functionality
  • Double-sided print, copy, scan and fax functionality as standard
  • Compact design with low-noise printing
  • Exceptionally low printing costs in its class
Why choose KYOCERA?
  • Efficient connectivity
    With interfaces like Gigabit LAN, USB 2.0, and USB host, the Kyocera ECOSYS M5526cdn ensures seamless connectivity and integration into any work environment, bolstering productivity and ease of use.
  • Advanced copying features
    The device offers automatic duplexing, multiple copying features such as 2 on 1, 4 on 1, Auto Color Mode, and ID Card Copy, alongside electronic sorting, making it a versatile tool for all copying needs.
  • High-quality printing
    Achieve high-quality print results with resolutions up to 9600 x 600 DPI for both black and white and color documents, ensuring your prints are professional and crisp every time.
  • Robust security
    Equipped with robust security protocols including IPsec and SSL, the Kyocera ECOSYS M5526cdn protects sensitive information, making it a reliable choice for businesses concerned with data security.
  • Eco-friendly design
    ENERGY STAR certified, this model promotes energy efficiency with a low power consumption operational mode, contributing to a greener office environment.
Kyocera ECOSYS M5526cdn - multifunction printer - colour
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Laser (colour)
Max Copying Speed
Up to 26 ppm (mono) / up to 26 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 9600 x 600 dpi (mono) / up to 9600 x 600 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
MH, MR, MMR, JBIG
Scanning
600 x 600 dpi
Display
4.3"
Original Size
Legal (216 x 356 mm)/A4 (210 x 297 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
70 x 148 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Plain paper
Standard Media Capacity
300 sheets
Max Media Capacity
550 sheets
Bypass Feeder Capacity
50 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, USB host
Office Machine Features
Scan to e-mail, scan to FTP, scan to SMB, scan to USB host
41.7 cm x 42.9 cm x 49.5 cm
26 kg
Environmental Standards
ENERGY STAR Qualified
Fax Type
Plain paper
Printing Technology
Laser - colour
Display Diagonal Size
4.3"
Display Features
Touch screen
Standard Memory
512 MB
Max Supported Memory
1.5 GB
Supported Flash Memory
SD Memory Card, SDHC Memory Card
Copying
Max Copying Speed
Grayscale Half-Tones
256
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Automatic Duplexing
Copying Features
2 on 1, 4 on 1, ID Card Copy, electronic sorting, Auto Color Mode, Scan-once-copy-many
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c, KPDL3, PCL 6 (XL), XPS, PRESCRIBE IIc
Automatic Duplexing
First Print Out Time B/W
9.5 sec
First Print Out Time Colour
10.5 sec
Scanning
Automatic Duplexing
Optical Resolution
600 x 600 dpi
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
MH, MR, MMR, JBIG
Reception Memory Capacity
Up to 256 pages
Fax Machine Features
Speed Dialing
100 station(s)
Remote Fax Retrieval (Polling)
Fax polling, Duplex Fax
Document & Media Handling
Max Original Size
Original Type
Sheets
50 sheets
Min Media Size
70 x 148 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Plain paper
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), B6 (125 x 176 mm), 70 x 148 mm
300 sheets
Max Media Capacity
550 sheets
50 sheets
150 sheets
Input tray - 250 sheets size: A6 (105 x 148 mm) - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Bypass tray - 50 sheets size: 70 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 220 g/m² , ADF - 50 sheets size: A6 (105 x 148 mm) - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 50 g/m² - 160 g/m² , Output tray - 150 sheets
Speed Details
Printing: up to 26 ppm (A4) - colour , Printing: up to 26 ppm (A4) - B/W , Copying: up to 26 ppm (A4) - B/W , Copying: up to 26 ppm (A4) - colour , Scanning: up to 30 ipm (A4) - B/W , Scanning: up to 23 ipm (A4) - colour , Scanning: up to 24 ipm (A4) - B/W duplex , Scanning: up to 16 ipm (A4) - colour duplex
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Security Protocols & Features
SSL, IPsec
Operating System Support
UNIX, Linux, MS Windows, Apple Mac OS X 10.8 or later
375 Watt
Power Consumption Standby
41 Watt
Power Consumption Sleep
1 Watt
Warm-Up Time
29 sec
First Copy Out Time B/W
8 sec
First Copy Out Time Colour
10 sec
Consumables Included
1 x toner cartridge (cyan) - up to 1200 pages , 1 x toner cartridge (magenta) - up to 1200 pages , 1 x toner cartridge (yellow) - up to 1200 pages , 1 x toner cartridge (black) - up to 1200 pages
ISO 9001, ISO 14001, AS/NZS 3260, ISO 7779, ISO 9296
ENERGY STAR Certified
41.7 cm
42.9 cm
49.5 cm
26 kg
Sound Emission
30 dBA (idle) / 49 dBA (operating)
CHKH Kyocera TK 5240K - black - original - toner cartridge In Stock £49.02
CHKH Kyocera TK 5240C - cyan - original - toner cartridge In Stock £72.89
CHKH Kyocera Black Toner Cassette 4K In Stock £49.02
CHKH Kyocera Cyan Toner Cassette 3K In Stock £72.89
CHKH Kyocera KYO Magenta Toner Cassette 3K In Stock £72.89
