The ECOSYS M5521cdn A4 professional all-rounder meets any business requirements. The scan, copy, fax and mobile scan functions ensure an optimized and flexible workflow. Mobile printing support takes this to the next level and, compatible with both mobile devices, offers every office the modern standards in technology. Additionally, the app offers you an easy way to operate this multifunctional printer from your smartphone. A powerful device, that fits perfectly into businesses, where a wide variety of functions are required.
- Up to 21 pages per minute in A4 in colour and black and white
- 1,200 dpi printing quality
- Mobile printing support including AirPrint, Mopria, KYOCERA Mobile Print
- Double-sided print, copy, scan and fax functionality as standard
- Direct printing from and scanning to USB flash memory
- Compact design with low-noise printing
- Exceptionally low printing costs in its class
Why choose KYOCERA?
- Kyocera ECOSYS M5521cdn - multifunction printer - colour
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Laser (colour)
- Max Copying Speed
- Up to 21 ppm (mono) / up to 21 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Up to 9600 x 600 dpi (mono) / up to 9600 x 600 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Data Compression System
- MH, MR, MMR, JBIG
- Scanning
- 600 x 600 dpi
- Original Size
- Legal (216 x 356 mm)/A4 (210 x 297 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 70 x 148 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Plain paper
- Standard Media Capacity
- 300 sheets
- Max Media Capacity
- 550 sheets
- Bypass Feeder Capacity
- 50 sheets
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB host
- AirPrint Enabled
- Office Machine Features
- Scan to e-mail, scan to FTP, scan to SMB, scan to USB host
- Power
- AC 230 V (50Hz)
- 41.7 cm x 42.9 cm x 49.5 cm
- 26 kg
- Environmental Standards
- ENERGY STAR Qualified
- Fax Type
- Plain paper
- Laser - colour
- Display
- 5 lines
- Interface
- AirPrint Enabled
- Standard Memory
- 512 MB
- Max Supported Memory
- 1.5 GB
- Supported Flash Memory
- SD Memory Card, SDHC Memory Card
Copying
- Max Copying Speed
- Grayscale Half-Tones
- 256
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 999
- Copying Features
- 2 on 1, 4 on 1, ID Card Copy, electronic sorting, Auto Color Mode, Scan-once-copy-many
Printing
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PCL 5c, KPDL3, PCL 6 (XL), PDF 1.7, XPS, PRESCRIBE IIc
- First Print Out Time B/W
- 11 sec
- First Print Out Time Colour
- 12.5 sec
Scanning
- Optical Resolution
- 600 x 600 dpi
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- MH, MR, MMR, JBIG
Fax Machine Features
- Speed Dialing
- 100 station(s)
- Remote Fax Retrieval (Polling)
- Fax polling
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 70 x 148 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Plain paper
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), B6 (125 x 176 mm), 70 x 148 mm
- 300 sheets
- 550 sheets
- 50 sheets
- 150 sheets
- Input tray - 250 sheets size: A6 (105 x 148 mm) - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Bypass tray - 50 sheets size: 70 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 220 g/m² , ADF - 50 sheets size: A6 (105 x 148 mm) - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 50 g/m² - 160 g/m² , Output tray - 150 sheets
- Speed Details
- Printing: up to 21 ppm (A4) - colour , Printing: up to 21 ppm (A4) - B/W , Copying: up to 21 ppm (A4) - B/W , Copying: up to 21 ppm (A4) - colour , Scanning: up to 30 ipm (A4) - B/W , Scanning: up to 23 ipm (A4) - colour
- 1 x USB 2.0 - 4 pin USB Type B ¦ 1 x USB host - 4 pin USB Type A ¦ 1 x Gigabit LAN - RJ-45
- Operating System Support
- UNIX, Linux, MS Windows, Apple Mac OS X 10.8 or later
- Voltage Required
- AC 230 V (50Hz)
- 345 Watt
- Power Consumption Standby
- 41 Watt
- Power Consumption Sleep
- 1 Watt
- Warm-Up Time
- 32 sec
- First Copy Out Time B/W
- 10 sec
- First Copy Out Time Colour
- 12 sec
- Consumables Included
- 1 x toner cartridge (cyan) - up to 1200 pages , 1 x toner cartridge (magenta) - up to 1200 pages , 1 x toner cartridge (yellow) - up to 1200 pages , 1 x toner cartridge (black) - up to 1200 pages
- ISO 9001, ISO 14001, AS/NZS 3260, ISO 7779, ISO 9296
- ENERGY STAR Certified
- 41.7 cm
- 42.9 cm
- 49.5 cm
- 26 kg
- Sound Emission
- 30 dBA (idle) / 48 dBA (operating)
Kyocera TK-5230C Cyan Toner Cassette | In Stock | £76.53 |
Kyocera TK-5230Y Yellow Toner | In Stock | £76.53 |
Kyocera TK-5220K Black Toner Cassette | In Stock | £44.30 |
Kyocera TK-5220C Cyan Toner Cassette | In Stock | £56.32 |
Kyocera TK-5220M Magenta Toner Cassette | In Stock | £54.33 |
Kyocera TK-5220Y Yellow Toner Cassette | In Stock | £54.81 |
Kyocera Black Toner Cassette 2.6K | In Stock | £52.02 |
Kyocera Cyan Toner Cassette 2.2K | In Stock | £76.53 |
Kyocera Magenta Toner Cassette 2.2K | In Stock | £76.53 |
Kyocera Yellow Toner Cassette 2.2K | In Stock | £76.53 |
Kyocera TK 5220C Cyan Original Toner Cartridge | In Stock | £52.51 |
Kyocera TK 5220M Magenta Original Toner Cartridge | In Stock | £52.51 |
Kyocera TK 5220Y Yellow Original Toner Cartridge | In Stock | £52.51 |
