Kyocera ECOSYS M5521cdn A4 Colour Laser Multifunction
Quicklinx: CHKFWS00 Mfr#: 1102RA3NL0
The ECOSYS M5521cdn A4 professional all-rounder meets any business requirements. The scan, copy, fax and mobile scan functions ensure an optimized and flexible workflow. Mobile printing support takes this to the next level and, compatible with both mobile devices, offers every office the modern standards in technology. Additionally, the app offers you an easy way to operate this multifunctional printer from your smartphone. A powerful device, that fits perfectly into businesses, where a wide variety of functions are required.
  • Up to 21 pages per minute in A4 in colour and black and white
  • 1,200 dpi printing quality
  • Mobile printing support including AirPrint, Mopria, KYOCERA Mobile Print
  • Double-sided print, copy, scan and fax functionality as standard
  • Direct printing from and scanning to USB flash memory
  • Compact design with low-noise printing
  • Exceptionally low printing costs in its class
Why choose KYOCERA?
Kyocera ECOSYS M5521cdn - multifunction printer - colour
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Laser (colour)
Max Copying Speed
Up to 21 ppm (mono) / up to 21 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 9600 x 600 dpi (mono) / up to 9600 x 600 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
MH, MR, MMR, JBIG
Scanning
600 x 600 dpi
Original Size
Legal (216 x 356 mm)/A4 (210 x 297 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
70 x 148 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Plain paper
Standard Media Capacity
300 sheets
Max Media Capacity
550 sheets
Bypass Feeder Capacity
50 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, Gigabit LAN, USB host
AirPrint Enabled
Office Machine Features
Scan to e-mail, scan to FTP, scan to SMB, scan to USB host
AC 230 V (50Hz)
41.7 cm x 42.9 cm x 49.5 cm
26 kg
Environmental Standards
ENERGY STAR Qualified
Fax Type
Plain paper
Printing Technology
Laser - colour
Display
5 lines
AirPrint Enabled
Standard Memory
512 MB
Max Supported Memory
1.5 GB
Supported Flash Memory
SD Memory Card, SDHC Memory Card
Copying
Max Copying Speed
Grayscale Half-Tones
256
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Copying Features
2 on 1, 4 on 1, ID Card Copy, electronic sorting, Auto Color Mode, Scan-once-copy-many
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c, KPDL3, PCL 6 (XL), PDF 1.7, XPS, PRESCRIBE IIc
Automatic Duplexing
First Print Out Time B/W
11 sec
First Print Out Time Colour
12.5 sec
Scanning
Optical Resolution
600 x 600 dpi
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
MH, MR, MMR, JBIG
Fax Machine Features
Speed Dialing
100 station(s)
Remote Fax Retrieval (Polling)
Fax polling
Document & Media Handling
Max Original Size
Original Type
Sheets
50 sheets
Min Media Size
70 x 148 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Plain paper
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), B6 (125 x 176 mm), 70 x 148 mm
300 sheets
Max Media Capacity
550 sheets
50 sheets
150 sheets
Input tray - 250 sheets size: A6 (105 x 148 mm) - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Bypass tray - 50 sheets size: 70 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 220 g/m² , ADF - 50 sheets size: A6 (105 x 148 mm) - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 50 g/m² - 160 g/m² , Output tray - 150 sheets
Speed Details
Printing: up to 21 ppm (A4) - colour , Printing: up to 21 ppm (A4) - B/W , Copying: up to 21 ppm (A4) - B/W , Copying: up to 21 ppm (A4) - colour , Scanning: up to 30 ipm (A4) - B/W , Scanning: up to 23 ipm (A4) - colour
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Operating System Support
UNIX, Linux, MS Windows, Apple Mac OS X 10.8 or later
AC 230 V (50Hz)
345 Watt
Power Consumption Standby
41 Watt
Power Consumption Sleep
1 Watt
Warm-Up Time
32 sec
First Copy Out Time B/W
10 sec
First Copy Out Time Colour
12 sec
Consumables Included
1 x toner cartridge (cyan) - up to 1200 pages , 1 x toner cartridge (magenta) - up to 1200 pages , 1 x toner cartridge (yellow) - up to 1200 pages , 1 x toner cartridge (black) - up to 1200 pages
ISO 9001, ISO 14001, AS/NZS 3260, ISO 7779, ISO 9296
ENERGY STAR Certified
41.7 cm
42.9 cm
49.5 cm
26 kg
Sound Emission
30 dBA (idle) / 48 dBA (operating)
CHKF Kyocera TK-5230C Cyan Toner Cassette In Stock £76.53
CHKF Kyocera TK-5230Y Yellow Toner In Stock £76.53
CHKF Kyocera TK-5220K Black Toner Cassette In Stock £42.78
CHKF Kyocera TK-5220C Cyan Toner Cassette In Stock £56.32
CHKF Kyocera TK-5220M Magenta Toner Cassette In Stock £54.60
CHKF Kyocera TK-5220Y Yellow Toner Cassette In Stock £54.60
CHKF Kyocera Black Toner Cassette 2.6K In Stock £52.02
CHKF Kyocera Cyan Toner Cassette 2.2K In Stock £76.53
CHKF Kyocera Magenta Toner Cassette 2.2K In Stock £76.53
CHKF Kyocera Yellow Toner Cassette 2.2K In Stock £76.53
CHKF Kyocera TK 5220C Cyan Original Toner Cartridge In Stock £52.51
CHKF Kyocera TK 5220M Magenta Original Toner Cartridge In Stock £52.51
CHKF Kyocera TK 5220Y Yellow Original Toner Cartridge In Stock £52.51
