Kyocera ECOSYS M4125idn Mono Laser Multifunction Printer
Quicklinx: GBHXWS00 Mfr#: 1102P23NL0
Hurry, only 1 left in stock!
£1,314.54 ex VAT
£1,577.44 inc VAT
This multifunctional device offers all the benefits of a professional document management solution for workgroups and small offices. Advanced functionality, easy to operate, and a range of paper-handling options, all in a well-designed compact package. Cost-efficient and eco-friendly offices will appreciate KYOCERA's unique ECOSYS technology which increases operating life, reduces environmental impact, cuts printing costs and ensures reliability.
  • Efficient connectivity
    With interfaces for Gigabit Ethernet, USB 2.0, and USB 2.0 host, this device ensures seamless integration into any office network, facilitating easy sharing and communication.
  • Advanced security
    Equipped with IPsec and SSL protocols, it offers robust security features to protect sensitive information and ensure peace of mind.
  • Versatile media handling
    Supports a wide range of media sizes from A6 to A3 and weights up to 256 g/m2, making it ideal for diverse printing needs, from standard documents to large-format prints.
  • High-quality copying
    Features like automatic duplexing, multiple copying features including ID Card Copy and electronic sorting, alongside a maximum copying resolution of 600 x 600 DPI, ensure crisp, clear copies every time.
  • Eco-friendly design
    ENERGY STAR certified, this device not only meets high environmental standards but also ensures efficient energy use, contributing to lower operating costs.
Kyocera ECOSYS M4125idn - multifunction printer - B/W
Multifunction printer
Printing Technology
Laser (monochrome)
Max Copying Speed
Up to 25 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 25 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Scanning
600 x 600 dpi
Display
4.3"
Original Size
98 x 148 mm (min) - A3/Ledger (297 x 432 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
98 x 148 mm (min) - A3 (297 x 420 mm), ANSI B (Ledger) (279 x 432 mm) (max)
Media Type
Plain paper
Standard Media Capacity
600 sheets
Max Media Capacity
1600 sheets
Output Trays Capacity
300 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, USB 2.0 host
Office Machine Features
Scan to e-mail, scan to folder, HyPAS (Hybrid Platform for Advanced Solutions), Private print, Kyocera ECOSYS Technology, scan to FTP, scan to SMB, print from e-mail, IPP printing, scan to USB host
AC 230 V (50/60Hz)
59 cm x 59 cm x 68.8 cm
49 kg
Environmental Standards
ENERGY STAR Qualified
Printing Technology
Laser - monochrome
Display Diagonal Size
4.3"
Display Colour Support
Display Features
Touch screen
Standard Memory
1 GB
Max Supported Memory
3 GB
Supported Flash Memory
SD Memory Card
Copying
Max Copying Speed
Up to 25 ppm
Up to 600 x 600 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Exposure Control
Automatic, manual
Exposure Modes
Text, photo, text and photo, map
Automatic Duplexing
Copying Features
2 on 1, 4 on 1, ID Card Copy, reverse copy, blank page skipping, electronic sorting, Scan-once-copy-many, programme mode
Printing
Max Printing Speed
Up to 25 ppm
Printer Drivers / Emulations
PCL 5e, PCL 6, PostScript 3, KPDL3, PCL 6 (XL), PDF, XPS, PRESCRIBE IIe
Automatic Duplexing
First Print Out Time B/W
5.8 sec
Scanning
Automatic Duplexing
Optical Resolution
600 x 600 dpi
Document & Media Handling
Min Original Size
98 x 148 mm
Max Original Size
Original Type
Sheets
50 sheets
Min Media Size
98 x 148 mm
Max Media Size
A3/Ledger
Min Media Weight
45 g/m²
Max Media Weight
256 g/m²
Supported Media Type
Plain paper
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), ANSI B (Ledger) (279 x 432 mm), Folio (216 x 330 mm)
600 sheets
Max Media Capacity
1600 sheets
300 sheets
Input tray - 500 sheets - A3/Ledger (297 x 432 mm) weight: 60 g/m² - 163 g/m² , Input tray - 100 sheets size: 98 x 148 mm - A3/Ledger (297 x 432 mm) weight: 45 g/m² - 256 g/m² , ADF - 50 sheets size: 140 x 182 mm - A3/Ledger (297 x 432 mm) weight: 45 g/m² - 160 g/m² , Output tray - 250 sheets , Job separator tray - 50 sheets
Speed Details
Printing: up to 25 ppm (A4) - B/W , Printing: up to 12 ppm (A3) - B/W , Copying: up to 25 ppm (A4) - B/W , Copying: up to 12 ppm (A3) - B/W , Scanning: up to 50 ipm (A4) - B/W (300 dpi) , Scanning: up to 20 ipm (A4) - colour (300 dpi) , Copying: up to 22 ppm (A4) - B/W duplex , Printing: up to 22 ppm (A4) - B/W duplex
1 x USB 2.0 - 4 pin USB Type B , 2 x USB 2.0 host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Security Protocols & Features
SSL, IPsec
Operating System Support
UNIX, Linux, Apple Mac OS X 10.5 or later, MS Windows
AC 230 V (50/60Hz)
410 Watt
Power Consumption Standby
65 Watt
Power Consumption Sleep
0.5 Watt
Warm-Up Time
20 sec
First Copy Out Time B/W
7 sec
TUV GS, ISO 9001, ISO 14001
ENERGY STAR Certified
59 cm
59 cm
68.8 cm
49 kg
Sound Emission
34 dBA (idle) / 49 dBA (operating)
Type: Printer / copier / scanner
Functionality: Copier
Functionality: Printer
Functionality: Scanner
Max Paper Size: A3 (297 x 420 mm)
Max Paper Size: ANSI B (Ledger) (279 x 432 mm)
Brand: Kyocera
Price Range Ex VAT: £1000 - £1500
