Kyocera ECOSYS M3550idn A4 Mono Laser Multifunction Printer
Quicklinx: C5YBWS00 Mfr#: 1102NM3NL0
Functionality: Fax, Scanner, Printer, Copier
Output Type: Monochrome
Technology: Laser
Max Print Speed: 50ppm
£1,316.95 ex VAT
£1,580.34 inc VAT
This very powerful MFP with speeds of up to 60 ppm is designed to handle even the largest print runs. It can be complemented with additional paper cassettes holding up to 2,600 pages in total and can easily be integrated into your existing business workflows thanks to the integrated open solution platform HyPAS. The long-life components guarantee the reliability and productivity you expect from a genuine KYOCERA device; you will certainly also appreciate their low printing costs and low environmental impact.
  • Efficient connectivity
    With options like Gigabit Ethernet, USB 2.0, and USB host, alongside AirPrint Enabled for seamless mobile printing, this device ensures you stay connected in an efficient way.
  • Advanced copying features
    Featuring automatic duplexing, a variety of copying features including 2 on 1, 4 on 1, ID Card Copy, and Sort, alongside exposure modes for photo, text, and text and photo, the Kyocera ECOSYS M3550idn enhances productivity and versatility.
  • High-speed performance
    Achieve high speeds with up to 50 ppm for both printing and copying in B/W, and a first print out time of just 8 sec, ensuring your work flows smoothly and efficiently.
  • Robust document handling
    From its 75-sheet ADF, 2600 sheets max media capacity, to supporting a wide range of media sizes and types, this device is designed to handle your documents with ease.
  • Eco-friendly and secure
    ENERGY STAR certified with advanced security protocols like IPsec and SSL, the Kyocera ECOSYS M3550idn is not only energy efficient but also ensures your data is protected.
Kyocera ECOSYS M3550idn - multifunction printer - B/W
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
250000 pages
Max Copying Speed
Up to 50 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 50 ppm
Max Printing Resolution
Up to 1800 x 600 dpi
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
MH, MR, MMR, JBIG
Fax Resolutions
200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi, 400 x 400 dpi
Scanning
600 x 600 dpi
Display
7"
Original Size
105 x 148 mm (min) - A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
75 sheets
Media Size
70 x 148 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Plain paper
Standard Media Capacity
600 sheets
Max Media Capacity
2600 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
500 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, USB host
AirPrint Enabled
Office Machine Features
Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to network, HyPAS (Hybrid Platform for Advanced Solutions), Kyocera ECOSYS Technology
AC 230 V (50/60Hz)
47.5 cm x 45.5 cm x 59 cm
23.3 kg
Environmental Standards
EPEAT Silver, ENERGY STAR Qualified
Fax Type
Plain paper
Printing Technology
Laser - monochrome
250000 pages
Display Diagonal Size
7"
Display Features
Touch screen, tilt
AirPrint Enabled
Standard Memory
1 GB
Max Supported Memory
2 GB
Supported Flash Memory
SD Memory Card, SDHC Memory Card
Copying
Max Copying Speed
Up to 50 ppm
Up to 600 x 600 dpi
Grayscale Half-Tones
256
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Exposure Modes
Text, photo, text and photo
Automatic Duplexing
Copying Features
2 on 1, 4 on 1, ID Card Copy, Sort
Printing
Max Printing Speed
Up to 50 ppm
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c, KPDL3, PCL 6 (XL), PDF 1.7, XPS, EPSON LQ-850, IBM Proprinter X24E, Lineprinter
Automatic Duplexing
First Print Out Time B/W
8 sec
Scanning
Automatic Duplexing
Optical Resolution
600 x 600 dpi
Grayscale Depth
8-bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
MH, MR, MMR, JBIG
Fax Resolutions
Fax Machine Features
One-Touch Dialing
22 station(s)
Document & Media Handling
Min Original Size
105 x 148 mm
Max Original Size
Original Type
Sheets
75 sheets
Min Media Size
70 x 148 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Plain paper
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm)
600 sheets
Max Media Capacity
2600 sheets
100 sheets
500 sheets
Input tray - 500 sheets size: 140 x 210 mm - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² , Bypass tray - 100 sheets size: 70 x 148 mm - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , ADF - 75 sheets size: 105 x 148 mm - Legal (216 x 356 mm) weight: 50 g/m² - 120 g/m² , Output tray - 500 sheets
Speed Details
Printing: up to 50 ppm (A4) - B/W , Copying: up to 50 ppm (A4) - B/W , Scanning: up to 60 ipm (A4) - B/W , Scanning: up to 40 ipm (A4) - colour
1 x USB 2.0 - 4 pin USB Type B , 2 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Security Protocols & Features
SSL, IPsec
Operating System Support
UNIX, Linux, Apple Mac OS X 10.5 or later, MS Windows
AC 230 V (50/60Hz)
777 Watt
Power Consumption Standby
70.8 Watt
Power Consumption Sleep
2.4 Watt
Warm-Up Time
21 sec
First Copy Out Time B/W
8 sec
Consumables Included
1 x toner cartridge (black) - up to 10000 pages
TUV, ISO 9001, GS, ISO 14001, ISO 7779
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
47.5 cm
45.5 cm
59 cm
23.3 kg
Sound Emission
23.6 dBA (idle) / 52.6 dBA (operating)
C5YB Kyocera Black Toner Cartridge 25k Yield In Stock £104.74
Functionality: Fax
Functionality: Scanner
Functionality: Printer
Functionality: Copier
Technology: Laser
Max Paper Size: A4 (210 x 297 mm)
Brand: Kyocera
Price Range Ex VAT: £1000 - £1500
