This MFP is made for dynamic teams with high demands as to productivity: it features printing speeds of 40 ppm and the 75-sheet reversing document processor scans at an impressive rate of 40 ipm. Its integrated file compression function makes it very easy for you to digitize and send large data electronically. Thanks to its long-life components, this device can achieve the exceptionally low running costs as well as the low environmental impact you come to expect from a genuine KYOCERA MFP.
Efficient connectivity
With features like Gigabit Ethernet, USB 2.0, and USB host, alongside AirPrint capability, this device ensures seamless integration into any work environment, allowing for easy connection and print jobs from various devices. -
Advanced copying features
The M3540dn excels in document management with features such as 2 on 1 and 4 on 1 copying, ID Card Copy, and automatic duplexing, making it a versatile tool for handling complex copying tasks efficiently. -
High-quality printing
Achieve crisp, clear printouts with a maximum resolution of 1800 x 600 DPI and a fast printing speed of 40 ppm, ensuring your documents look professional and are ready when you need them. -
Robust document handling
Designed to support a wide range of media sizes and types, this printer can handle up to 2600 sheets, making it ideal for high-volume printing tasks without constant reloads. -
Eco-friendly design
ENERGY STAR certification signifies this printer's commitment to energy efficiency, helping reduce operational costs and environmental impact.
- Kyocera ECOSYS M3540dn - multifunction printer - B/W
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 150000 pages
- Max Copying Speed
- Up to 40 ppm
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 40 ppm
- Max Printing Resolution
- Up to 1800 x 600 dpi
- Max Fax Transmission Speed
- 33.6 Kbps
- Data Compression System
- MH, MR, MMR, JBIG
- Fax Resolutions
- 200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi, 400 x 400 dpi
- Scanning
- 600 x 600 dpi
- Original Size
- 105 x 148 mm (min) - A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 75 sheets
- Media Size
- 70 x 148 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Plain paper
- Standard Media Capacity
- 600 sheets
- Max Media Capacity
- 2600 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 250 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB host
- AirPrint Enabled
- Office Machine Features
- Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to network, Kyocera ECOSYS Technology
- Power
- AC 230 V (50/60Hz)
- 47.5 cm x 45.5 cm x 57.5 cm
- 21.5 kg
- Environmental Standards
- ENERGY STAR Qualified
- Fax Type
- Plain paper
- Laser - monochrome
- 150000 pages
- Display
- 5 lines
- Interface
- AirPrint Enabled
- Standard Memory
- 512 MB
- Max Supported Memory
- 1.5 GB
- Supported Flash Memory
- SD Memory Card, SDHC Memory Card
Copying
- Max Copying Speed
- Up to 40 ppm
- Grayscale Half-Tones
- 256
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 999
- Exposure Modes
- Text, photo, text and photo
- Copying Features
- 2 on 1, 4 on 1, ID Card Copy, Sort
Printing
- Up to 40 ppm
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PCL 5c, KPDL3, PCL 6 (XL), PDF 1.7, XPS, EPSON LQ-850, IBM Proprinter X24E, Lineprinter
- First Print Out Time B/W
- 9 sec
Scanning
- Optical Resolution
- 600 x 600 dpi
- Grayscale Depth
- 8-bit
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- MH, MR, MMR, JBIG
- Fax Resolutions
Fax Machine Features
- One-Touch Dialing
- 22 station(s)
Document & Media Handling
- Min Original Size
- 105 x 148 mm
- Max Original Size
- Original Type
- Sheets
- 75 sheets
- Min Media Size
- 70 x 148 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Plain paper
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm)
- 600 sheets
- 2600 sheets
- 100 sheets
- 250 sheets
- Input tray - 500 sheets size: 140 x 210 mm - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² , Bypass tray - 100 sheets size: 70 x 148 mm - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , ADF - 75 sheets size: 105 x 148 mm - Legal (216 x 356 mm) weight: 50 g/m² - 120 g/m² , Output tray - 250 sheets
- Speed Details
- Printing: up to 40 ppm (A4) - B/W , Copying: up to 40 ppm (A4) - B/W , Scanning: up to 40 ipm (A4) - B/W , Scanning: up to 30 ipm (A4) - colour
- 1 x USB 2.0 - 4 pin USB Type B ¦ 2 x USB host - 4 pin USB Type A ¦ 1 x Gigabit LAN - RJ-45
- SSL, IPsec
- Operating System Support
- UNIX, Linux, Apple Mac OS X 10.5 or later, MS Windows
- Voltage Required
- 680 Watt
- Power Consumption Standby
- 54.7 Watt
- Power Consumption Sleep
- 2.6 Watt
- Warm-Up Time
- 21 sec
- First Copy Out Time B/W
- 9 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 6000 pages
- TUV, ISO 9001, GS, ISO 14001, ISO 7779
- ENERGY STAR Certified
- 47.5 cm
- 45.5 cm
- 57.5 cm
- 21.5 kg
- Sound Emission
- 26.5 dBA (idle) / 51.1 dBA (operating)
