Kyocera ECOSYS M3540dn A4 Mono Laser Multifunction Printer
Quicklinx: C5Y8WS00 Mfr#: 1102NZ3NL0
Functionality: Scanner, Printer, Copier, Fax
Output Type: Monochrome
Technology: Laser
Max Print Speed: 40ppm
£815.37 ex VAT
£978.44 inc VAT
This MFP is made for dynamic teams with high demands as to productivity: it features printing speeds of 40 ppm and the 75-sheet reversing document processor scans at an impressive rate of 40 ipm. Its integrated file compression function makes it very easy for you to digitize and send large data electronically. Thanks to its long-life components, this device can achieve the exceptionally low running costs as well as the low environmental impact you come to expect from a genuine KYOCERA MFP.
  • Efficient connectivity
    With features like Gigabit Ethernet, USB 2.0, and USB host, alongside AirPrint capability, this device ensures seamless integration into any work environment, allowing for easy connection and print jobs from various devices.
  • Advanced copying features
    The M3540dn excels in document management with features such as 2 on 1 and 4 on 1 copying, ID Card Copy, and automatic duplexing, making it a versatile tool for handling complex copying tasks efficiently.
  • High-quality printing
    Achieve crisp, clear printouts with a maximum resolution of 1800 x 600 DPI and a fast printing speed of 40 ppm, ensuring your documents look professional and are ready when you need them.
  • Robust document handling
    Designed to support a wide range of media sizes and types, this printer can handle up to 2600 sheets, making it ideal for high-volume printing tasks without constant reloads.
  • Eco-friendly design
    ENERGY STAR certification signifies this printer's commitment to energy efficiency, helping reduce operational costs and environmental impact.
Kyocera ECOSYS M3540dn - multifunction printer - B/W
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
150000 pages
Max Copying Speed
Up to 40 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 40 ppm
Max Printing Resolution
Up to 1800 x 600 dpi
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
MH, MR, MMR, JBIG
Fax Resolutions
200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi, 400 x 400 dpi
Scanning
600 x 600 dpi
Original Size
105 x 148 mm (min) - A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
75 sheets
Media Size
70 x 148 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Plain paper
Standard Media Capacity
600 sheets
Max Media Capacity
2600 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
250 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, USB host
AirPrint Enabled
Office Machine Features
Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to network, Kyocera ECOSYS Technology
AC 230 V (50/60Hz)
47.5 cm x 45.5 cm x 57.5 cm
21.5 kg
Environmental Standards
ENERGY STAR Qualified
Fax Type
Plain paper
Printing Technology
Laser - monochrome
150000 pages
Display
5 lines
AirPrint Enabled
Standard Memory
512 MB
Max Supported Memory
1.5 GB
Supported Flash Memory
SD Memory Card, SDHC Memory Card
Copying
Max Copying Speed
Up to 40 ppm
Up to 600 x 600 dpi
Grayscale Half-Tones
256
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Exposure Modes
Text, photo, text and photo
Automatic Duplexing
Copying Features
2 on 1, 4 on 1, ID Card Copy, Sort
Printing
Max Printing Speed
Up to 40 ppm
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c, KPDL3, PCL 6 (XL), PDF 1.7, XPS, EPSON LQ-850, IBM Proprinter X24E, Lineprinter
Automatic Duplexing
First Print Out Time B/W
9 sec
Scanning
Automatic Duplexing
Optical Resolution
600 x 600 dpi
Grayscale Depth
8-bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
MH, MR, MMR, JBIG
Fax Resolutions
Fax Machine Features
One-Touch Dialing
22 station(s)
Document & Media Handling
Min Original Size
105 x 148 mm
Max Original Size
Original Type
Sheets
75 sheets
Min Media Size
70 x 148 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Plain paper
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm)
600 sheets
Max Media Capacity
2600 sheets
100 sheets
250 sheets
Input tray - 500 sheets size: 140 x 210 mm - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² , Bypass tray - 100 sheets size: 70 x 148 mm - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , ADF - 75 sheets size: 105 x 148 mm - Legal (216 x 356 mm) weight: 50 g/m² - 120 g/m² , Output tray - 250 sheets
Speed Details
Printing: up to 40 ppm (A4) - B/W , Copying: up to 40 ppm (A4) - B/W , Scanning: up to 40 ipm (A4) - B/W , Scanning: up to 30 ipm (A4) - colour
1 x USB 2.0 - 4 pin USB Type B , 2 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Security Protocols & Features
SSL, IPsec
Operating System Support
UNIX, Linux, Apple Mac OS X 10.5 or later, MS Windows
AC 230 V (50/60Hz)
680 Watt
Power Consumption Standby
54.7 Watt
Power Consumption Sleep
2.6 Watt
Warm-Up Time
21 sec
First Copy Out Time B/W
9 sec
Consumables Included
1 x toner cartridge (black) - up to 6000 pages
TUV, ISO 9001, GS, ISO 14001, ISO 7779
ENERGY STAR Certified
47.5 cm
45.5 cm
57.5 cm
21.5 kg
Sound Emission
26.5 dBA (idle) / 51.1 dBA (operating)
C5Y8 Kyocera FS2100 Toner Kit 12.5K Yield In Stock £77.18
Functionality: Printer
Functionality: Copier
Functionality: Fax
Technology: Laser
Max Paper Size: A4 (210 x 297 mm)
Brand: Kyocera
Price Range Ex VAT: £750 - £1000
