Kyocera ECOSYS M2735DW A4 Mono Laser Multifunction
Quicklinx: CKQ7WS00 Mfr#: 1102SG3NL0
11 In Stock
£333.74 ex VAT
£400.48 inc VAT
A productive solution for workgroups that require a wide variety of output sizes from A6 up to A3. This fast and compact printer offers an expandable paper capacity of up to 6 paper trays for flexible paper handling. Plus this team-player knows exactly how to impress with comprehensive security features and ECOSYS long-life technology that gives you exceptionally low cost per page and less waste.«
Kyocera ECOSYS M2735dw - multifunction printer - B/W
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
20000 pages
Max Printing Speed
Up to 35 ppm
Max Printing Resolution
Up to 1200 dpi
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
MH, MR, MMR, JBIG
Fax Resolutions
406 x 391 dpi, 200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi, 400 x 400 dpi
Scanning
600 x 600 dpi
Display
4.3"
Original Size
100 x 148 mm (min) - Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
70 x 148 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper
Standard Media Capacity
350 sheets
Max Media Capacity
850 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, Gigabit LAN, USB host, Wi-Fi
AirPrint Enabled
Office Machine Features
Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to network, Kyocera ECOSYS Technology, scan to FTP, scan to SMB, scan to USB host
AC 230 V (50/60Hz)
41.7 cm x 41.2 cm x 43.7 cm
19 kg
Environmental Standards
ENERGY STAR Qualified
Fax Type
Plain paper
Printing Technology
Laser - monochrome
20000 pages
Display Diagonal Size
4.3"
Display Features
Touch screen
AirPrint Enabled
Standard Memory
512 MB
Max Supported Memory
1.5 GB
Supported Flash Memory
SD Memory Card
Copying
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Exposure Control
Manual
Exposure Modes
Text and photo, text / photo / map
Copying Features
2 on 1, 4 on 1, ID Card Copy, Multiple Copy, blank page skipping, electronic sorting
Printing
Up to 1200 dpi
Max Printing Speed
Up to 35 ppm
Printer Drivers / Emulations
PCL 5e, PCL 6, PostScript 3, KPDL3, PCL 6 (XL), PDF, XPS, PRESCRIBE IIc
Automatic Duplexing
First Print Out Time B/W
6.8 sec
Colour Management Features
Mopria
Scanning
Optical Resolution
600 x 600 dpi
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
MH, MR, MMR, JBIG
Fax Resolutions
Fax Machine Features
Fax polling, Duplex Fax
Document & Media Handling
Min Original Size
100 x 148 mm
Max Original Size
Original Type
Sheets
50 sheets
Min Media Size
70 x 148 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Media Thickness Range
Up to 0.11 mm
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), B6 (125 x 176 mm)
350 sheets
Max Media Capacity
850 sheets
100 sheets
150 sheets
Input tray - 250 sheets size: A6 (105 x 148 mm) - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , Bypass tray - 100 sheets size: 70 x 148 mm - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , ADF - 50 sheets size: 100 x 148 mm - Legal (216 x 356 mm) weight: 50 g/m² - 160 g/m² , Output tray - 150 sheets
Speed Details
Printing: up to 35 ppm (A4) - B/W , Scanning: up to 40 ipm (A4) - B/W (300 dpi) , Scanning: up to 23 ipm (A4) - colour (300 dpi)
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Security Protocols & Features
LDAP
Operating System Support
UNIX, Linux, Apple Mac OS X 10.5 or later, MS Windows
AC 230 V (50/60Hz)
661 Watt
Power Consumption Standby
21 Watt
Power Consumption Sleep
1 Watt
Warm-Up Time
20 sec
First Copy Out Time B/W
6.9 sec
Consumables Included
1 x toner cartridge (black) - up to 1000 pages
TUV, ISO 9001, GS, ISO 14001, ISO 7779, ISO/IEC 19752
ENERGY STAR Certified
41.7 cm
41.2 cm
43.7 cm
19 kg
Sound Emission
47.2 dBA (operating)
Ink (2)
CKQ7 Kyocera TK-1150 Black Toner - 3K In Stock £60.48
CKQ7 Kyocera TK 1150 Black Original Toner Cartridge In Stock £57.72
Other bundles (2)
CKQ7 Kyocera 3Yr Group B Onsite Next Day Warranty In Stock £99.01
CKQ7 Kyocera PF-1100 250 Sheet Paper Feeder In Stock £167.31
Functionality: Copier
Functionality: Printer
Functionality: Fax
Functionality: Scanner
Max Paper Size: A4 (210 x 297 mm)
Brand: Kyocera
