A productive solution for workgroups that require a wide variety of output sizes from A6 up to A3. This fast and compact printer offers an expandable paper capacity of up to 6 paper trays for flexible paper handling. Plus this team-player knows exactly how to impress with comprehensive security features and ECOSYS long-life technology that gives you exceptionally low cost per page and less waste.«
- Kyocera ECOSYS M2735dw - multifunction printer - B/W
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 20000 pages
- Max Printing Speed
- Up to 35 ppm
- Max Printing Resolution
- Up to 1200 dpi
- Max Fax Transmission Speed
- 33.6 Kbps
- Data Compression System
- MH, MR, MMR, JBIG
- Fax Resolutions
- 406 x 391 dpi, 200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi, 400 x 400 dpi
- Scanning
- 600 x 600 dpi
- Display
- 4.3"
- Original Size
- 100 x 148 mm (min) - Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 70 x 148 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper
- Standard Media Capacity
- 350 sheets
- Max Media Capacity
- 850 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB host, Wi-Fi
- AirPrint Enabled
- Office Machine Features
- Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to network, Kyocera ECOSYS Technology, scan to FTP, scan to SMB, scan to USB host
- Power
- AC 230 V (50/60Hz)
- 41.7 cm x 41.2 cm x 43.7 cm
- 19 kg
- Environmental Standards
- ENERGY STAR Qualified
- Fax Type
- Plain paper
- Laser - monochrome
- 20000 pages
- Display Diagonal Size
- 4.3"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Standard Memory
- 512 MB
- Max Supported Memory
- 1.5 GB
- Supported Flash Memory
- SD Memory Card
Copying
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 999
- Exposure Control
- Manual
- Exposure Modes
- Text and photo, text / photo / map
- Copying Features
- 2 on 1, 4 on 1, ID Card Copy, Multiple Copy, blank page skipping, electronic sorting
Printing
- Up to 1200 dpi
- Up to 35 ppm
- Printer Drivers / Emulations
- PCL 5e, PCL 6, PostScript 3, KPDL3, PCL 6 (XL), PDF, XPS, PRESCRIBE IIc
- First Print Out Time B/W
- 6.8 sec
- Colour Management Features
- Mopria
Scanning
- Optical Resolution
- 600 x 600 dpi
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- MH, MR, MMR, JBIG
- Fax Resolutions
Fax Machine Features
- Fax polling, Duplex Fax
Document & Media Handling
- Min Original Size
- 100 x 148 mm
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 70 x 148 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 220 g/m²
- Media Thickness Range
- Up to 0.11 mm
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), B6 (125 x 176 mm)
- 350 sheets
- 850 sheets
- 100 sheets
- 150 sheets
- Input tray - 250 sheets size: A6 (105 x 148 mm) - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , Bypass tray - 100 sheets size: 70 x 148 mm - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , ADF - 50 sheets size: 100 x 148 mm - Legal (216 x 356 mm) weight: 50 g/m² - 160 g/m² , Output tray - 150 sheets
- Speed Details
- Printing: up to 35 ppm (A4) - B/W , Scanning: up to 40 ipm (A4) - B/W (300 dpi) , Scanning: up to 23 ipm (A4) - colour (300 dpi)
- 1 x USB 2.0 - 4 pin USB Type B ¦ 1 x USB host - 4 pin USB Type A ¦ 1 x Gigabit LAN - RJ-45
- LDAP
- Operating System Support
- UNIX, Linux, Apple Mac OS X 10.5 or later, MS Windows
- Voltage Required
- 661 Watt
- Power Consumption Standby
- 21 Watt
- Power Consumption Sleep
- 1 Watt
- Warm-Up Time
- 20 sec
- First Copy Out Time B/W
- 6.9 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 1000 pages
- TUV, ISO 9001, GS, ISO 14001, ISO 7779, ISO/IEC 19752
- ENERGY STAR Certified
- 41.7 cm
- 41.2 cm
- 43.7 cm
- 19 kg
- Sound Emission
- 47.2 dBA (operating)
Ink (2)
Kyocera TK-1150 Black Toner - 3K | In Stock | £60.93 |
Kyocera TK 1150 Black Original Toner Cartridge | In Stock | £57.72 |
Other bundles (2)
Kyocera 3Yr Group B Onsite Next Day Warranty | In Stock | £99.01 |
Kyocera PF-1100 250 Sheet Paper Feeder | In Stock | £167.31 |
