Kyocera ECOSYS M2635dn Mono Laser 35ppm Multifunction Printer
Quicklinx: DVBXWS00 Mfr#: 1102S13NL0
Functionality: Scanner, Fax, Printer, Copier
Output Type: Monochrome
Technology: Laser
Max Print Speed: 35ppm
£337.96 ex VAT
£405.55 inc VAT
The M2635dn is an extremely reliable device with high print quality, duplex printing, Gigabit Ethernet and overall fast scanning and copying. It's perfectly suited for demanding desktop users and small workgroups. And you shouldn't worry about placing it in open space offices either: operation is remarkably quiet.
  • Efficient connectivity
    With interfaces for Gigabit Ethernet, USB 2.0, and USB host, the Kyocera ECOSYS M2635dn ensures seamless integration into any office network, facilitating easy sharing and management of documents.
  • Advanced copying features
    The device offers versatile copying features including 2 on 1, 4 on 1, ID Card Copy, Scan-once-copy-many, and electronic sorting, enhancing productivity and document management efficiency.
  • High-quality printing
    Automatic duplexing and a maximum printing speed of 35 ppm, combined with a resolution of 1200 DPI, ensure fast and clear monochrome outputs, suitable for professional documents.
  • Robust scanning capabilities
    A high optical resolution of 600 x 600 DPI and fast scanning speeds up to 40 ipm in B/W and 23 ipm in color make digitizing documents both quick and sharp.
  • Eco-friendly design
    Adhering to GS, ISO 14001, and ISO 9001 standards, the Kyocera ECOSYS M2635dn is designed with sustainability in mind, ensuring efficient operation and minimal environmental impact.
Kyocera ECOSYS M2635dn - multifunction printer - B/W
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
20000 pages
Recommended Monthly Volume
2000 pages
Max Printing Speed
Up to 35 ppm
Max Printing Resolution
Up to 1200 dpi
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
MH, MR, MMR, JBIG
Fax Resolutions
200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi, 400 x 400 dpi
Scanning
600 x 600 dpi
Original Size
A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
100 sheets
Media Size
216 x 356 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Plain paper
Standard Media Capacity
350 sheets
Max Media Capacity
850 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (printing)
USB 2.0, Gigabit LAN, USB host
Office Machine Features
Save to USB flash drive, scan to e-mail, scan to network
AC 230 V (50/60Hz)
41.7 cm x 41.2 cm x 43.7 cm
19 kg
Fax Type
Plain paper
Printing Technology
Laser - monochrome
20000 pages
2000 pages
Display
7 lines
Standard Memory
512 MB
Max Supported Memory
1.5 GB
Copying
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Exposure Control
Manual
Exposure Modes
Text, photo, text and photo, map
Copying Features
2 on 1, 4 on 1, ID Card Copy, electronic sorting, Scan-once-copy-many
Printing
Up to 1200 dpi
Max Printing Speed
Up to 35 ppm
Printer Drivers / Emulations
PCL 5e, PCL 6, PCL 5c, KPDL3, PCL 6 (XL), PDF, XPS, PRESCRIBE IIc
Automatic Duplexing
First Print Out Time B/W
6.8 sec
Scanning
Optical Resolution
600 x 600 dpi
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
MH, MR, MMR, JBIG
Fax Resolutions
Document & Media Handling
Max Original Size
Original Type
Sheets
100 sheets
Min Media Size
216 x 356 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Plain paper
350 sheets
Max Media Capacity
850 sheets
150 sheets
Paper cassette - 250 sheets size: A6 (105 x 148 mm) - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , Input tray - 100 sheets size: 70 x 148 mm - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , Output tray - 150 sheets
Speed Details
Printing: up to 35 ppm (A4) - B/W , Scanning: up to 40 ipm (A4) - B/W , Scanning: up to 23 ipm (A4) - colour
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Security Protocols & Features
LDAP
Operating System Support
UNIX, Linux, Apple Mac OS X 10.5 or later, MS Windows
AC 230 V (50/60Hz)
661 Watt
Power Consumption Standby
21 Watt
Power Consumption Sleep
1 Watt
Warm-Up Time
17 sec
First Copy Out Time B/W
6.9 sec
Consumables Included
1 x toner cartridge (black) - up to 1000 pages
TUV, ISO 9001, GS, ISO 14001
41.7 cm
41.2 cm
43.7 cm
19 kg
Sound Emission
47.2 dBA (operating)
Ink (1)
DVBX Kyocera TK 1150 Black Original Toner Cartridge In Stock £57.68
Other bundles (2)
DVBX Kyocera 3Yr Group B Onsite Next Day Warranty In Stock £99.70
DVBX Kyocera PF-1100 250 Sheet Paper Feeder In Stock £163.89
Functionality: Fax
Functionality: Printer
Functionality: Copier
Technology: Laser
Max Paper Size: A4 (210 x 297 mm)
Brand: Kyocera
