The M2635dn is an extremely reliable device with high print quality, duplex printing, Gigabit Ethernet and overall fast scanning and copying. It's perfectly suited for demanding desktop users and small workgroups. And you shouldn't worry about placing it in open space offices either: operation is remarkably quiet.
Efficient connectivity
With interfaces for Gigabit Ethernet, USB 2.0, and USB host, the Kyocera ECOSYS M2635dn ensures seamless integration into any office network, facilitating easy sharing and management of documents. -
Advanced copying features
The device offers versatile copying features including 2 on 1, 4 on 1, ID Card Copy, Scan-once-copy-many, and electronic sorting, enhancing productivity and document management efficiency. -
High-quality printing
Automatic duplexing and a maximum printing speed of 35 ppm, combined with a resolution of 1200 DPI, ensure fast and clear monochrome outputs, suitable for professional documents. -
Robust scanning capabilities
A high optical resolution of 600 x 600 DPI and fast scanning speeds up to 40 ipm in B/W and 23 ipm in color make digitizing documents both quick and sharp. -
Eco-friendly design
Adhering to GS, ISO 14001, and ISO 9001 standards, the Kyocera ECOSYS M2635dn is designed with sustainability in mind, ensuring efficient operation and minimal environmental impact.
- Kyocera ECOSYS M2635dn - multifunction printer - B/W
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 20000 pages
- Recommended Monthly Volume
- 2000 pages
- Max Printing Speed
- Up to 35 ppm
- Max Printing Resolution
- Up to 1200 dpi
- Max Fax Transmission Speed
- 33.6 Kbps
- Data Compression System
- MH, MR, MMR, JBIG
- Fax Resolutions
- 200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi, 400 x 400 dpi
- Scanning
- 600 x 600 dpi
- Original Size
- A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 100 sheets
- Media Size
- 216 x 356 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Plain paper
- Standard Media Capacity
- 350 sheets
- Max Media Capacity
- 850 sheets
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (printing)
- Interface
- USB 2.0, Gigabit LAN, USB host
- Office Machine Features
- Save to USB flash drive, scan to e-mail, scan to network
- Power
- AC 230 V (50/60Hz)
- 41.7 cm x 41.2 cm x 43.7 cm
- 19 kg
- Fax Type
- Plain paper
- Laser - monochrome
- 20000 pages
- 2000 pages
- Display
- 7 lines
- Interface
- Standard Memory
- 512 MB
- Max Supported Memory
- 1.5 GB
Copying
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 999
- Exposure Control
- Manual
- Exposure Modes
- Text, photo, text and photo, map
- Copying Features
- 2 on 1, 4 on 1, ID Card Copy, electronic sorting, Scan-once-copy-many
Printing
- Up to 1200 dpi
- Up to 35 ppm
- Printer Drivers / Emulations
- PCL 5e, PCL 6, PCL 5c, KPDL3, PCL 6 (XL), PDF, XPS, PRESCRIBE IIc
- First Print Out Time B/W
- 6.8 sec
Scanning
- Optical Resolution
- 600 x 600 dpi
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- MH, MR, MMR, JBIG
- Fax Resolutions
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 100 sheets
- Min Media Size
- 216 x 356 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Plain paper
- 350 sheets
- 850 sheets
- 150 sheets
- Paper cassette - 250 sheets size: A6 (105 x 148 mm) - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , Input tray - 100 sheets size: 70 x 148 mm - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , Output tray - 150 sheets
- Speed Details
- Printing: up to 35 ppm (A4) - B/W , Scanning: up to 40 ipm (A4) - B/W , Scanning: up to 23 ipm (A4) - colour
- 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
- LDAP
- Operating System Support
- UNIX, Linux, Apple Mac OS X 10.5 or later, MS Windows
- Voltage Required
- 661 Watt
- Power Consumption Standby
- 21 Watt
- Power Consumption Sleep
- 1 Watt
- Warm-Up Time
- 17 sec
- First Copy Out Time B/W
- 6.9 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 1000 pages
- TUV, ISO 9001, GS, ISO 14001
- 41.7 cm
- 41.2 cm
- 43.7 cm
- 19 kg
- Sound Emission
- 47.2 dBA (operating)
Ink (2)
Kyocera TK-1150 Black Toner - 3K | In Stock | £64.58 |
Kyocera TK 1150 Black Original Toner Cartridge | In Stock | £58.94 |
Other bundles (1)
Kyocera PF-1100 250 Sheet Paper Feeder | In Stock | £167.31 |
