The M2135dn is an affordable model in the ECOSYS series, yet are still full of features. As extremely reliable devices with 1,200 dpi b/w print quality, duplex printing, gigabit Ethernet and overall fast scanning and copying, both are perfectly suited for demanding desktop users and small workgroups.
And you shouldn't worry about placing these in open space offices either: Operation is remarkably quiet and, with even smaller dimensions than their predecessors, they fit on virtually every desk. Finally, thanks to many flexible paper-handling options, each device can be customised to meet your demands precisely.
Efficient document handling
With a maximum media capacity of 850 sheets and support for sizes up to Legal (216 x 356 mm), the Kyocera ECOSYS M2135dn streamlines office workflows and handles large print jobs with ease. Its versatile document feeder and media handling capabilities ensure that all printing, copying, and scanning tasks are performed efficiently. -
Advanced connectivity
Equipped with Gigabit Ethernet, USB 2.0, and USB host interfaces, along with Apple AirPrint for mobile printing capabilities, this device ensures seamless integration into any modern office environment. Secure LDAP support further enhances its functionality in connected workspaces. -
High-quality output
Achieve crisp, clear monochrome printing with a resolution of 1200 DPI and a first print out time of just 6.8 seconds. Automatic duplexing and a robust monthly duty cycle of up to 20,000 pages make it an ideal choice for businesses looking for reliability and quality in their document production.
- Kyocera ECOSYS M2135dn - multifunction printer - B/W
- Multifunction printer
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 20000 pages
- Max Printing Speed
- Up to 35 ppm
- Max Printing Resolution
- Up to 1200 dpi
- Scanning
- 600 x 600 dpi
- Original Size
- 100 x 148 mm (min) - Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 70 x 148 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper
- Standard Media Capacity
- 350 sheets
- Max Media Capacity
- 850 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB host
- AirPrint Enabled
- Office Machine Features
- Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to network, Kyocera ECOSYS Technology, scan to FTP, scan to SMB, scan to USB host
- Power
- AC 230 V (50/60Hz)
- 41.7 cm x 41.2 cm x 43.7 cm
- 19 kg
- Environmental Standards
- ENERGY STAR Qualified
- Laser - monochrome
- 20000 pages
- Display
- 5 lines
- Interface
- AirPrint Enabled
- Standard Memory
- 512 MB
- Max Supported Memory
- 1.5 GB
- Supported Flash Memory
- SD Memory Card, SDHC Memory Card
Copying
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 999
- Exposure Control
- Manual
- Exposure Modes
- Text and photo, text / photo / map
- Copying Features
- 2 on 1, 4 on 1, ID Card Copy, Multiple Copy, blank page skipping, electronic sorting
Printing
- Up to 1200 dpi
- Up to 35 ppm
- Printer Drivers / Emulations
- PCL 5e, PCL 6, PostScript 3, KPDL3, PCL 6 (XL), PDF, XPS, PRESCRIBE IIc
- First Print Out Time B/W
- 6.8 sec
- Colour Management Features
- Mopria
Scanning
- Optical Resolution
- 600 x 600 dpi
Document & Media Handling
- Min Original Size
- 100 x 148 mm
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 70 x 148 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 220 g/m²
- Media Thickness Range
- Up to 0.11 mm
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), B6 (125 x 176 mm)
- 350 sheets
- 850 sheets
- 100 sheets
- 150 sheets
- Input tray - 250 sheets size: A6 (105 x 148 mm) - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , Bypass tray - 100 sheets size: 70 x 148 mm - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , ADF - 50 sheets size: 100 x 148 mm - Legal (216 x 356 mm) weight: 50 g/m² - 160 g/m² , Output tray - 150 sheets
- Speed Details
- Printing: up to 35 ppm (A4) - B/W , Scanning: up to 40 ipm (A4) - B/W (300 dpi) , Scanning: up to 23 ipm (A4) - colour (300 dpi)
- 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
- LDAP
- Operating System Support
- UNIX, Linux, Apple Mac OS X 10.5 or later, MS Windows
- Voltage Required
- 661 Watt
- Power Consumption Standby
- 21 Watt
- Power Consumption Sleep
- 1 Watt
- Warm-Up Time
- 17 sec
- First Copy Out Time B/W
- 6.9 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 1000 pages
- TUV, ISO 9001, GS, ISO 14001, ISO 7779, ISO/IEC 19752
- ENERGY STAR Certified
- 41.7 cm
- 41.2 cm
- 43.7 cm
- 19 kg
- Sound Emission
- 47.2 dBA (operating)
