Kyocera ECOSYS M2135dn A4 Mono Laser Multifunction Printer
Quicklinx: CPKHWS00 Mfr#: 1102S03NL0
£230.04 ex VAT
£276.04 inc VAT
The M2135dn is an affordable model in the ECOSYS series, yet are still full of features. As extremely reliable devices with 1,200 dpi b/w print quality, duplex printing, gigabit Ethernet and overall fast scanning and copying, both are perfectly suited for demanding desktop users and small workgroups.
And you shouldn't worry about placing these in open space offices either: Operation is remarkably quiet and, with even smaller dimensions than their predecessors, they fit on virtually every desk. Finally, thanks to many flexible paper-handling options, each device can be customised to meet your demands precisely.
  • Efficient document handling
    With a maximum media capacity of 850 sheets and support for sizes up to Legal (216 x 356 mm), the Kyocera ECOSYS M2135dn streamlines office workflows and handles large print jobs with ease. Its versatile document feeder and media handling capabilities ensure that all printing, copying, and scanning tasks are performed efficiently.
  • Advanced connectivity
    Equipped with Gigabit Ethernet, USB 2.0, and USB host interfaces, along with Apple AirPrint for mobile printing capabilities, this device ensures seamless integration into any modern office environment. Secure LDAP support further enhances its functionality in connected workspaces.
  • High-quality output
    Achieve crisp, clear monochrome printing with a resolution of 1200 DPI and a first print out time of just 6.8 seconds. Automatic duplexing and a robust monthly duty cycle of up to 20,000 pages make it an ideal choice for businesses looking for reliability and quality in their document production.
Kyocera ECOSYS M2135dn - multifunction printer - B/W
Multifunction printer
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
20000 pages
Max Printing Speed
Up to 35 ppm
Max Printing Resolution
Up to 1200 dpi
Scanning
600 x 600 dpi
Original Size
100 x 148 mm (min) - Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
70 x 148 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper
Standard Media Capacity
350 sheets
Max Media Capacity
850 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, Gigabit LAN, USB host
AirPrint Enabled
Office Machine Features
Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to network, Kyocera ECOSYS Technology, scan to FTP, scan to SMB, scan to USB host
AC 230 V (50/60Hz)
41.7 cm x 41.2 cm x 43.7 cm
19 kg
Environmental Standards
ENERGY STAR Qualified
Printing Technology
Laser - monochrome
20000 pages
Display
5 lines
AirPrint Enabled
Standard Memory
512 MB
Max Supported Memory
1.5 GB
Supported Flash Memory
SD Memory Card, SDHC Memory Card
Copying
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Exposure Control
Manual
Exposure Modes
Text and photo, text / photo / map
Copying Features
2 on 1, 4 on 1, ID Card Copy, Multiple Copy, blank page skipping, electronic sorting
Printing
Up to 1200 dpi
Max Printing Speed
Up to 35 ppm
Printer Drivers / Emulations
PCL 5e, PCL 6, PostScript 3, KPDL3, PCL 6 (XL), PDF, XPS, PRESCRIBE IIc
Automatic Duplexing
First Print Out Time B/W
6.8 sec
Colour Management Features
Mopria
Scanning
Optical Resolution
600 x 600 dpi
Document & Media Handling
Min Original Size
100 x 148 mm
Max Original Size
Original Type
Sheets
50 sheets
Min Media Size
70 x 148 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Media Thickness Range
Up to 0.11 mm
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), B6 (125 x 176 mm)
350 sheets
Max Media Capacity
850 sheets
100 sheets
150 sheets
Input tray - 250 sheets size: A6 (105 x 148 mm) - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , Bypass tray - 100 sheets size: 70 x 148 mm - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , ADF - 50 sheets size: 100 x 148 mm - Legal (216 x 356 mm) weight: 50 g/m² - 160 g/m² , Output tray - 150 sheets
Speed Details
Printing: up to 35 ppm (A4) - B/W , Scanning: up to 40 ipm (A4) - B/W (300 dpi) , Scanning: up to 23 ipm (A4) - colour (300 dpi)
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Security Protocols & Features
LDAP
Operating System Support
UNIX, Linux, Apple Mac OS X 10.5 or later, MS Windows
AC 230 V (50/60Hz)
661 Watt
Power Consumption Standby
21 Watt
Power Consumption Sleep
1 Watt
Warm-Up Time
17 sec
First Copy Out Time B/W
6.9 sec
Consumables Included
1 x toner cartridge (black) - up to 1000 pages
TUV, ISO 9001, GS, ISO 14001, ISO 7779, ISO/IEC 19752
ENERGY STAR Certified
41.7 cm
41.2 cm
43.7 cm
19 kg
Sound Emission
47.2 dBA (operating)
Ink (1)
CPKH Kyocera TK 1150 Black Original Toner Cartridge In Stock £58.86
Other bundles (1)
CPKH Kyocera PF-1100 250 Sheet Paper Feeder In Stock £167.31
Type: Printer / copier / scanner
Functionality: Printer
Functionality: Scanner
Functionality: Copier
Max Paper Size: A4 (210 x 297 mm)
Brand: Kyocera
