These two devices are ready to become key players in your office. With a print speed of 40 pages per minute, short first print and first copy times and professional scanning features, including simultaneous scanning of both document sides, they will surely help boost the productivity in their respective workgroups. Their low TCO makes them a very affordable and reasonable choice. Toner and paper capacity are equally impressive too. They are extremely reliable, meaning you can stay productive as long as you need to.
Efficient connectivity
With features like Gigabit Ethernet, USB 2.0, and USB host, alongside mobile printing capabilities through Apple AirPrint, this device ensures seamless integration into any work environment. -
Advanced copying features
Offers automatic duplexing and a variety of copying features such as 2 on 1, 4 on 1, ID Card Copy, and electronic sorting, enhancing productivity and document management efficiency. -
Robust document handling
Equipped with a 50-sheet Automatic Document Feeder (ADF) and a maximum media capacity of 850 sheets, this printer can handle large jobs with ease, supporting media sizes up to Legal (216 x 356 mm). -
Eco-friendly operation
ENERGY STAR certified, the Kyocera ECOSYS M2040dn is designed for sustainability, featuring a low power consumption sleep mode of just 1 W, aligning with eco-conscious business practices. -
High-quality printing and scanning
Delivers monochrome printing with a maximum resolution of 1200 DPI and supports automatic duplexing in both printing and scanning, ensuring high-quality outputs and efficient workflows.
- Kyocera ECOSYS M2040dn - multifunction printer - B/W
- Multifunction printer
- Fax Type
- Plain paper
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 50000 pages
- Max Printing Speed
- Up to 40 ppm
- Max Printing Resolution
- Up to 1200 dpi
- Scanning
- 600 x 600 dpi
- Original Size
- 100 x 148 mm (min) - Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 70 x 148 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper
- Standard Media Capacity
- 350 sheets
- Max Media Capacity
- 850 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB host
- AirPrint Enabled
- Office Machine Features
- Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to network, Kyocera ECOSYS Technology, scan to FTP, scan to SMB, scan to USB host
- Power
- AC 230 V (50/60Hz)
- 41.7 cm x 41.2 cm x 43.7 cm
- 19 kg
- Environmental Standards
- ENERGY STAR Qualified
- Fax Type
- Plain paper
- Laser - monochrome
- 50000 pages
- Display
- 5 lines
- Interface
- AirPrint Enabled
- Standard Memory
- 512 MB
- Max Supported Memory
- 1.5 GB
- Supported Flash Memory
- SD Memory Card
Copying
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 999
- Exposure Control
- Manual
- Exposure Modes
- Text and photo, text / photo / map
- Copying Features
- 2 on 1, 4 on 1, ID Card Copy, Multiple Copy, blank page skipping, electronic sorting
Printing
- Up to 1200 dpi
- Up to 40 ppm
- Printer Drivers / Emulations
- PCL 5e, PCL 6, PostScript 3, KPDL3, PCL 6 (XL), PDF, XPS, PRESCRIBE IIc
- First Print Out Time B/W
- 6.4 sec
- Colour Management Features
- Mopria
Scanning
- Optical Resolution
- 600 x 600 dpi
Document & Media Handling
- Min Original Size
- 100 x 148 mm
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 70 x 148 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 220 g/m²
- Media Thickness Range
- Up to 0.11 mm
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), B6 (125 x 176 mm)
- 350 sheets
- 850 sheets
- 100 sheets
- 150 sheets
- Input tray - 250 sheets size: A6 (105 x 148 mm) - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , Bypass tray - 100 sheets size: 70 x 148 mm - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , ADF - 50 sheets size: 100 x 148 mm - Legal (216 x 356 mm) weight: 50 g/m² - 160 g/m² , Output tray - 150 sheets
- Speed Details
- Printing: up to 40 ppm (A4) - B/W , Scanning: up to 40 ipm (A4) - B/W , Scanning: up to 23 ipm (A4) - colour
- 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
- LDAP
- Operating System Support
- UNIX, Linux, Apple Mac OS X 10.5 or later, MS Windows
- Voltage Required
- 661 watt
- Power Consumption Standby
- 21 watt
- Power Consumption Sleep
- 1 watt
- Warm-Up Time
- 17 sec
- First Copy Out Time B/W
- 6.4 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 3600 pages
- TUV, ISO 9001, GS, ISO 14001, ISO 7779, ISO/IEC 19752
- ENERGY STAR Certified
- 41.7 cm
- 41.2 cm
- 43.7 cm
- 19 kg
- Sound Emission
- 48.3 dBA (operating)
