The compact A4 MFP can increase the productivity of any office. It has print and copy speeds of up to 30 pages per minute and a time to first print of only 6 seconds. The large-capacity document processor scans double-sided originals and makes it easy to master large digitization projects. You can quickly and easily access all the functionalities needed via the well-structured 5-line LCD display.
- Up to 30 pages per minute in A4
- Time to first copy: 6.9 seconds
- 5-line LCD display for clear messages and ease of use
- Print, copy, scan functionality as standard
- Duplex unit for cost-saving double-sided printing
- 50-sheet document processor scans double-sided originals
- Copy double sided ID cards on a single sheet of paper with ease
- Exceptionally low printing costs in its class
- Kyocera ECOSYS M2030dn - multifunction printer - B/W
- Multifunction printer
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 20000 images
- Max Printing Speed
- Up to 30 ppm
- Max Printing Resolution
- Up to 1800 x 600 dpi
- Scanning
- 600 dpi
- Original Size
- 140 x 210 mm (min) - Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 70 x 148 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Plain paper
- Standard Media Capacity
- 300 sheets
- Max Media Capacity
- 800 sheets
- Bypass Feeder Capacity
- 50 sheets
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB host
- AirPrint Enabled
- Office Machine Features
- Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to network, Kyocera ECOSYS Technology
- Power
- AC 230 V (50/60Hz)
- 49.4 cm x 43 cm x 44.8 cm
- 18 kg
- Environmental Standards
- ENERGY STAR Qualified
- Laser - monochrome
- 20000 images
- Display
- 5 lines
- Interface
- AirPrint Enabled
- Standard Memory
- 512 MB
- Max Supported Memory
- 1.5 GB
- Supported Flash Memory
- SD Memory Card
Copying
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 999
- Exposure Modes
- Text, photo, text and photo
- Copying Features
- 2 on 1, 4 on 1, ID Card Copy, Sort, Multiple Copy
Printing
- Up to 30 ppm
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PCL 5c, KPDL3, PCL 6 (XL), PDF 1.7, XPS, EPSON LQ-850, IBM Proprinter X24E, Lineprinter
- First Print Out Time B/W
- 7 sec
Scanning
- Optical Resolution
- 600 dpi
- Grayscale Depth
- 8-bit
Document & Media Handling
- Min Original Size
- 140 x 210 mm
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 70 x 148 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Plain paper
- 300 sheets
- 800 sheets
- 50 sheets
- 150 sheets
- Input tray - 250 sheets size: A6 (105 x 148 mm) - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² , Bypass tray - 50 sheets size: 70 x 148 mm - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , ADF - 50 sheets size: 140 x 210 mm - Legal (216 x 356 mm) weight: 50 g/m² - 120 g/m² , Output tray - 150 sheets
- Speed Details
- Printing: up to 30 ppm (A4) - B/W , Scanning: up to 35 ipm (A4) - B/W , Scanning: up to 14 ipm (A4) - colour
- 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
- LDAP, SSL, IPsec
- Operating System Support
- UNIX, Linux, Apple MacOS X 10.4 or later, MS Windows
- Voltage Required
- 431 Watt
- Power Consumption Standby
- 62 Watt
- Power Consumption Sleep
- 3.7 Watt
- Warm-Up Time
- 20 sec
- First Copy Out Time B/W
- 6.9 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 1000 pages
- TUV, ISO 9001, GS, ISO 14001, ISO 7779
- ENERGY STAR Certified
- 49.4 cm
- 43 cm
- 44.8 cm
- 18 kg
- Sound Emission
- 28.3 dBA (idle) / 50.4 dBA (operating)
