Kyocera A4 Colour Laser Printer 30ppm Mono 30ppm Colour 600 x 600 dp
Quicklinx: BQL3WS00 Mfr#: 1102NR3NLO
This versatile colour printing solution contains our renowned long-life components which help to reduce waste and ensure exceptional levels of reliability. With up to five paper sources the printer allows for different media sizes and weights up to 220g/m². And as well as its great performance it’s extremely energy-efficient – a bonus for both the environment and your budget.
Kyocera ECOSYS P6130cdn - printer - colour - laser
Printer Type
Workgroup printer - laser - colour
28 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
70 mm x 148 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 30 ppm - B/W - A4 (210 x 297 mm) , Up to 30 ppm - colour - A4 (210 x 297 mm)
Max Resolution (B&W)
9600 x 600 dpi
Max Resolution (Colour)
9600 x 600 dpi
Automatic Duplexing
USB 2.0, Gigabit LAN, USB host
AirPrint Enabled
PowerPC 465S 1 GHz
RAM Installed (Max)
512 MB (2 GB)
Language Simulation
PCL 5C, PostScript 3, PCL 6, PCL XL, KPDL3, XPS, PDF 1.7
Barcodes
UCC/EAN-128, EAN/JAN-8, EAN/JAN-13, PDF417
Media Type
Plain paper
Total Media Capacity
600 sheets
Media Handling
100-sheet multipurpose tray, 500-sheet input tray
Monthly Duty Cycle (max)
100000 pages
Print server
Printer Features
Kyocera ECOSYS Technology
AC 230V
UNIX, Linux, Microsoft Windows, Apple MacOS X 10.5 or later
39 cm x 53.2 cm x 40.95 cm
Printer Type
Printer
Print Speed
Built-in Devices
Status LCD
Wired
AirPrint Enabled
9600 x 600 dpi
9600 x 600 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
7 sec
First Print Out Time Colour
8 sec
Language Simulation
Fonts Included
93 x scalable , 1 x bitmapped , 45 x barcode
Barcodes
Printer Features
Media Handling
PowerPC 465S 1 GHz
RAM
RAM Installed (Max)
512 MB / 2 GB (max)
Media Handling
Media Type
Plain paper
Media Size Class
A4/Legal
Max Media Size
70 mm x 148 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), B6 (125 x 176 mm)
Media Weight
60 g/m² - 220 g/m²
600 sheets
Media Feeders
1 x automatic - 100 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , 1 x automatic - 500 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m²
Max Media Capacity
2100 sheets
Output Trays Capacity
250 sheets
Duty Cycle
100000 pages
Print server
Remote Management Protocol
SNMP 3, HTTPS, IPPS
Security Protocols & Features
SSL, IPsec
Expansion Slots
1 x expansion slot
1 x USB 2.0 - 4 pin USB Type B , 2 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Consumables Included
1 x toner cartridge (black) - up to 3500 pages ISO/IEC 19798 , 1 x toner cartridge (yellow) - up to 2500 pages ISO/IEC 19798 , 1 x toner cartridge (cyan) - up to 2500 pages ISO/IEC 19798 , 1 x toner cartridge (magenta) - up to 2500 pages ISO/IEC 19798
TUV, ISO 9001, GS, ISO 14001
Power supply - internal
AC 230V
Frequency Required
50/60 Hz
479 Watt
Power Consumption Sleep
2 Watt
Environmental Standards
ENERGY STAR
Limited warranty - 2 years - carry-in
Sound Emission (Operating)
49.2 dBA
Sound Emission (Quiet Mode)
46.3 dBA
39 cm
53.2 cm
40.95 cm
28 kg
