Kyocera MDDR2-256 DDR2 256 MB DIMM 144-pin - for Kyocera FS-1035, 6525, 6530; ECOSYS LS 4020; FS-13XX, 4020, C5100, C5200, C5250 and C5300.
Efficient memory upgrade
This memory module provides a capacity of 256 MB, which boosts multitasking capabilities and system responsiveness for a smoother computing experience. -
Compatible form factor
Featuring a DIMM 144-pin form factor, this memory module is designed for straightforward installation and compatibility with a wide range of systems.
- Kyocera MDDR2-256 - DDR2 - module - 256 MB - DIMM 144-pin
- Product Type
- Memory module
- Capacity
- 256 MB
- Memory Type
- DDR2 SDRAM - DIMM 144-pin
- Upgrade Type
- System specific
- Designed For
- Kyocera FS-1035, FS-6525, FS-6530; ECOSYS LS 4020; FS-1320, 1350, 2020, 3900, 3920, 4020, C5100, C5200, C5250, C5300
- Capacity
- 256 MB
- Upgrade Type
- System specific
- DRAM memory module
- Technology
- DDR2 SDRAM
- Form Factor
- DIMM 144-pin
- Compatible Slots
- 1 x memory - DIMM 144-pin
- Designed For
- Kyocera FS-1035MFP, FS-6525MFP/KL3, FS-6525MFP/KL3FAX, FS-6530MFP, FS-6530MFP/KL3, FS-6530MFP/KL3FAX , Kyocera ECOSYS LS 4020DN , Kyocera FS-1320DN/KL3, 1350DN, 2020D, 2020D/KL3, 2020DN, 2020DN/KL3, 3900DN, 3920DN, 3920DN/KL3, 4020DN, 4020DN/KL3, C5100DN, C5100DN/KL3, C5200DN, C5200DN/KL3, C5250DN, C5300DN, C5300DN/KL3
