The VM-16H is a distribution amplifier for HDMI signals. It reclocks and equalizes the signal and distributes it to 16 identical outputs.
Kramer Equalization & re-Klocking technology
Rebuilds the digital signal integrity to travel longer distances. -
I-EDIDPro Kramer Intelligent EDID Processing
Intelligent EDID handling and processing algorithm ensures Plug and Play operation for HDMI systems.
- Kramer VM-16H distribution amplifier
- Distribution amplifier
- 48.3 cm - 17.8 cm
- 4.5 kg
- 3 years
- 48.3 cm
- 17.8 cm
- 4.5 kg
Studio & Production Equipment
- HDCP compliant
- Voltage Required
- AC 120/230 V
- Frequency
- 50/60 Hz
Terminals
- Terminals
- (1) x HDMI input - 19 pin HDMI Type A , (16) x HDMI output - 19 pin HDMI Type A
- Warranty
- 3 years
