Konica Minolta magicolor 1650EN
Quicklinx: 5FS3WS00 Mfr#: A034022
The magicolor 1650EN is Konica Minolta's compact color network printer for small workgroups. It is stylish, affordable and flexible, making it the perfect choice for daily printing tasks. Being very easy to use, it takes only minutes to install into a network. As an added bonus, you will appreciate its extremely quiet operation, eco-friendliness and impressive color quality.
  • Versatile printing power
    Whatever you want to print, the magicolor 1650EN gives you perfect results every time. With its standard Emperon controller it is PCL and PS compatible and at home in Windows, Mac and Linux environments. Its powerful memory ensures fast processing of all print jobs, while Konica Minolta's Simitri HD polymerized toner provides a brilliant print quality, applying clarity and definition to the tiniest detail. Thanks to Simitri HD's increased resistance to UV light prints are impressively long-lasting.
  • Flexible media handling
    Print what you like with your magicolor 1650EN, right there in your office. This printer impresses with its versatile media qualities and processes plain paper, thick paper, envelopes, labels, postcard stock etc. For you, this means producing your own business cards, envelopes, colorful presentations, leaflets and more. And if the standard paper supply of 200 sheets leaves you a bit short, simply add extra flexibility with the lower paper feeder that gives you another 500 sheets. Flexibility can also be had with the automatic duplex unit that makes double-sided printing fast, convenient and completely automatic.
  • Clean Planet program for the environment
    In the interest of environmental conservation, Konica Minolta strives to reduce the impact of its products at each stage of the product lifecycle. As one aspect the Clean Planet program gives you the opportunity to recycle your used toner cartridges for free. Cartridges are recycled efficiently and cleanly, preserving precious resources. Returning the cartridges is quick, easy and completely free for you!
  • Big on ease of use
    The magicolor 1650EN is virtually ready to print as soon as you take it out of its box - it really is as easy as that! Operation is simple and intuitive via its clearly structured LCD display; and with PageScope web connection you will find it easy to check the printer and consumables status directly at your PC monitor. Finally, straightforward access from the front makes your printer easy to handle, too.
Konica Minolta magicolor 1650EN - printer - colour - laser
Printer Type
Workgroup printer - laser - colour
Desktop
15.1 kg
Media Size Class
A4/Legal
Max Media Size
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm)
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 5 ppm - colour - A4 (210 x 297 mm) , Up to 20 ppm - B/W - A4 (210 x 297 mm)
Image Enhancement Technology
Photo ART-9600 (600 x 600 dpi x 4-bit contone)
USB, LAN
Zoran Quatro 4230 400 MHz
RAM Installed (Max)
256 MB
Language Simulation
PCL 5E, PCL 5C, PostScript 3, PCL 6, HP GL/2
Media Type
Envelopes, labels, plain paper, recycled paper, thick paper
Total Media Capacity
200 sheets
Media Handling
200-sheet input tray
Monthly Duty Cycle (max)
500 pages
Print server - Ethernet, Fast Ethernet
SuSE Linux 8.2, Red Hat Linux 9, Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Apple MacOS X 10.2 or later, Microsoft Windows Server 2003, Apple MacOS X Server 10.2 or later, Microsoft Windows Server 2003 x64 Edition, Microsoft Windows Server 2008, Apple MacOS X 10.5, Microsoft Windows Vista (32/64 bits)
Microsoft Certification
Compatible with Windows 7
1-year warranty
39.6 cm x 38 cm x 27.5 cm
Printer Type
Desktop
Printer
Print Speed
Wired
USB, LAN
First Print Out Time B/W
13 sec
First Print Out Time Colour
22 sec
Language Simulation
Fonts Included
146 x PostScript , 97 x PCL
Media Handling
RAM
RAM Installed (Max)
256 MB
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), C6 (114 x 162 mm)
Envelope Sizes
International DL (110 x 220 mm), International C6 (114 x 162 mm)
Media Weight
60 g/m² - 209 g/m²
200 sheets
Media Feeders
1 x automatic - 200 sheets
Max Media Capacity
700 sheets
Output Trays Capacity
100 sheets
Duty Cycle
500 pages
Print server
Expansion Slots
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
Consumables Included
1 x toner cartridge (cyan) - up to 500 pages , 1 x toner cartridge (magenta) - up to 500 pages , 1 x toner cartridge (yellow) - up to 500 pages , 1 x toner cartridge (black) - up to 1000 pages
GS, EMC, WEEE
Power supply - internal
Frequency Required
50/60 Hz
510 Watt
Power Consumption Stand by / Sleep
22 Watt
Environmental Standards
ENERGY STAR
Limited warranty - parts and labour - 1 year - on-site
10 °C
35 °C
15 - 85%
Sound Emission (Idle)
29 dB
Sound Emission (Operating)
50 dB
39.6 cm
38 cm
27.5 cm
15.1 kg
Resources
The following resources are available for the Konica Minolta magicolor 1650EN
