Konftel 55 Conferencing Unit
Quicklinx: B13FWS00 Mfr#: 910101071
The Konftel 55 is an easy-to-use, compact conference unit with impressive, crystal-clear sound thanks to the patented audio technology OmniSound HD. The Konftel 55 has been specially designed to be the hub of your communications and connects computers, mobile phones/tablets and desktop phones. Whatever the communication tools, your meetings will be conducted with superior sound quality. Moreover, VoIP calls can be bridged with calls via a desktop or mobile phone. Combine and switch connections easily on the LCD screen's smart user interface that only displays the current connections. Make a call and the meeting is under way! The Konftel 55 lets you record calls or dictations and you can move the memory card to your computer to save or share the audio files. The Konftel 55 is highly portable and looks just as good on the desktop and in the home office as in the conference room.
  • Connects to your UC app
    The Konftel 55 is fully compatible with the market's leading UC applications. The speakerphone connects directly to Skype for Business, Cisco Jabber or Avaya Communicator on your computer. The app's call functions are controlled from the touchscreen. If you prefer a different conferencing tool, the Konftel 55 is still a high-quality USB audio device.
  • A convenient hub
    The Konftel 55 serves as a hub for your communications, connecting to computers, mobile phones/tablets and desk phones. Calls via a computer can be bridged with calls via a desk phone or mobile phone. Switch and combine connections easily on the touchscreen, which only shows the options available at the time.
  • Smart features
    Record calls or dictations onto a memory card and save, play or share the audio files with ease. The Konftel 55 is light to carry around with you and looks just as good on a desk and in a home office as it does in a conference room. The software is constantly being improved and can be updated easily using a tool on your computer. This makes the speakerphone a future-proof investment.
  • A highly convenient video solution
    Are you after a package solution for huddle and medium sized rooms? The Konftel C2055 collaboration kit combines the Konftel 55 with the Konftel Cam20, which delivers 4K Ultra HD and a razor-sharp image. The Konftel OCC Hub brings the whole package together, so a single USB cable is all you need to connect the conference cam, the sound device and the room's screen to the collaboration app on your laptop.
  • Climate neutral products
    Konftel is certified in line with the Climate Neutral standard. This means that we have offset all our greenhouse gas emissions and are taking action to further reduce those emissions. When you choose a Konftel product, you keep a clear climate conscience while supporting your organization's growing need for video collaboration. Keep an eye out for the Climate Neutral Certified label, which indicates that all our products are climate neutral.
Konftel 55 - conference phone
Conference phone
Package Content
Conference phone console
Speakerphone
Call Services
Caller ID, Call Hold
Display
LCD display - colour - Yes
Display Features
Touch screen
Body Colour
Liquorice black and silver
Conference phone
Body Colour
Phone Features
Call Services
Conference Call Capability
Speakerphone
Volume Control
Additional Functions
Built-in clock, voice recording
Conference Phone
Package Content
OmniSound, USB connection for VoIP calls
IP Telephony
VoIP
Display
Display Location
Base
Display Resolution
240 x 320 pixels
Backlit
Touch screen
Supported Flash Memory Cards
SDHC
USB / mini-USB Type B , Headset jack / mini-phone 3.5mm
USB cable
Power adapter
Dimensions & Weight (Base)
22.2 cm
20.6 cm
6.8 cm
640 g
