Brand
Konftel 250 Conference Phone
Quicklinx: 7F2BWS00 Mfr#: 910101065
£254.00 ex VAT
£304.80 inc VAT
Konftel 250 is an excellent choice for holding telephone conferences with great sound quality. It's the obvious choice when you have an analog line - high performance, smart features and expandable too. The Konftel 250 is equipped with Konftel's patented OmniSound 2.0 audio technology, for crystal-clear sound. Save your contacts in the phone book and use the conference guide to easily set up multi-party calls or pre-programmed group calls. Konftel 250 also has a built-in recording function that enables you to record your calls on an SD memory card. With its modern Scandinavian design, Konftel 250 will be a welcome addition to any conference room. Hold productive telephone conference meetings that not only save time but the environment as well by cutting travel expenses.
  • Grows with the task
    The Konftel 250 is designed for small to medium conference rooms. It includes the option to connect a pair of expansion microphones to increase the pickup range for use in larger situations. The phone is equipped with Konftel's OmniSound audio technology for crystal-clear sound in both directions
  • Smart features
    Save contacts in the phone book. The conference guide will take you through the steps to set up a multi-party call and create call groups. Record important calls on an SD memory card, as back-up for notes or to share at a later date.
  • Scandinavian design
    The audio is expertly designed around our OmniSound technology, which comes as standard in all our products. The style of the Konftel 250 is anything but standard, allowing it to take pride of place in the finest conference rooms. The classic Scandinavian design is both visually appealing and functional.
  • Climate neutral products
    Konftel is certified in line with the Climate Neutral standard. This means that we have offset all our greenhouse gas emissions and are taking action to further reduce those emissions. When you choose a Konftel product, you keep a clear climate conscience while supporting your organization's growing need for video collaboration. Keep an eye out for the Climate Neutral Certified label, which indicates that all our products are climate neutral.
Konftel 250 - conference phone
Conference phone
Package Content
Conference phone console
Speakerphone
Yes (digital duplex)
Call Services
Call Hold
Display
LCD display - monochrome - Yes
Body Colour
Charcoal black
Conference phone
Body Colour
Charcoal black
Phone Features
Call Services
Call Hold
Dialer Type
Keypad
Dialer Location
Base
Conference Call Capability
Speakerphone
Voice Recording
Menu Operation
Function Buttons
Conference button, directory button, flash button, mute button, hold button
Volume Control
Ringer Control
Indicators
Visual ringer light, hold indicator
Additional Functions
Built-in clock, voice recording
Additional Features
Built-in SD card slot
Conference Phone
Package Content
Noise cancellation, OmniSound
Phone Memory
Phone Directory Capacity
50 names & numbers
Display
Display Location
Base
Display Resolution
128 x 64 pixels
Backlit
Display Languages
Danish, English, German, French, Italian, Norwegian, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish
Supported Flash Memory Cards
SD Memory Card
2 x microphone jack
Phone line cable
Power adapter
FCC Class B certified, FCC Class C certified, IC CS-03, FCC CFR47 Part 68, UL 60950-1, EN 60950-1, TBR21, EN 301 489-1, EN 301 489-3
Power adapter - external
Dimensions & Weight (Base)
24 cm
24 cm
7.7 cm
1 kg
Type: Conference phone
Brand: Konftel
