Kodak Scanmate i1120
Quicklinx: 586NWS00 Mfr#: 8456923
The KODAK SCANMATE i1120 Scanner transforms your paper documents into high-quality digital images that can be managed, sent, filed, and found easily. One push of a button puts you in control of your documents and organizes your information.
The KODAK SCANMATE i1120 is ready to scan right out of the box, with one simple computer connection and intuitive bundled software. With the smart touch feature, you can easily pre-program up to nine scanning functions, along with the file formats you need them in PDF, TIFF, JPEG, RTF, and searchable PDF.
Scan anything from a business card to documents up to 86 cm (34 in.) long, in color, grayscale, black and white, one-sided or two. Even when they are imperfect, Perfect Page technology can make scanned images look better than the originals. This robust desktop scanner gives you all the ease, flexibility, reliability, and quality you want, at a price that is just where you want it.
  • Smart Touch feature
    The Kodak Scanmate i1120 Scanner has all the ease of use and versatility you're looking for - no matter what the job is. Kodak Smart Touch feature enables you to select the right scanning application for the job.
  • Perfect Page feature
    Perfect Page scanning is a suite of image processing technologies that maximizes the quality of digital images. And it's only available in KODAK Scanners. Even when your document is less than perfect, Perfect Page corrects for color, brightness, contrast, readability, orientation and background so your scanned images may actually look better than the original.
Kodak SCANMATE i1120 - document scanner - desktop - USB 2.0
Document scanner - desktop
Interface Type
USB 2.0
Max Supported Document Size
215 x 863 mm
Input Type
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
20 ppm (mono) / 20 ppm (colour)
Max Document Size
215 mm x 863 mm
Automatic Duplexing
Document Feeder Type
Automatic
Document Storage Capacity
50 sheets
Duty Cycle
1000 scans per day
Microsoft Windows 2000 Professional SP4, Microsoft Windows Vista (32/64 bits) SP1, Microsoft Windows Server 2003 x64 Edition, Microsoft Windows XP 64-bit Edition SP2, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP SP2 (32 bit), Microsoft Windows XP (32-bit) SP3
Microsoft Certification
Compatible with Windows 7
30.06 cm x 15.73 cm x 14.75 cm
2.7 kg
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Interface Type
USB 2.0
215 x 863 mm
Scanner
Input Type
Optical Resolution
600 dpi x 600 dpi
Automatic Duplexing
Max Document Scan Speed B/W
20 ppm
Max Document Scan Speed Colour
20 ppm
Duty Cycle
1000 scans per day
Scanner Speed Details
20 ppm - portrait B&W - Letter - 200 dpi , 20 ppm - portrait greyscale - Letter - 200 dpi , 20 ppm - portrait colour - Letter - 200 dpi , 40 ipm - duplex - portrait B&W - Letter - 200 dpi , 40 ipm - duplex - portrait greyscale - Letter - 200 dpi , 40 ipm - duplex - portrait colour - Letter - 200 dpi
TWAIN, ISIS, WIA
Media Handling
Max Document Size
215 mm x 863 mm
Automatic
50 sheets
Interfaces Details
USB 2.0 - Type B
FCC Class B certified, TUV GS, VCCI Class B ITE, CISPR 22 Class B, cUL, EN 61000-3-3, EN55024, EN55022 Class B, ICES-003 Class B, CCC, UL 60950-1, IEC 60950-1, EN 60950-1, S Mark, GB 4943, GB 17625.1, AS/NZS, CAN/CSA C22.2 No. 60950-1-03
ENERGY STAR Certified
Internal power supply
Software Included
Drivers & Utilities, Presto! BizCard, Nuance PaperPort, Nuance OmniPage, KODAK Smart Touch
System Requirements Details
Core 2 Duo - 2.66 GHz - RAM 4 GB
30.06 cm
15.73 cm
14.75 cm
2.7 kg
Limited warranty - replacement - 1 year
