Kodak PS50 Picture Saver Scanning System
Quicklinx: 9KY0WS00 Mfr#: 1993807
  • Windows 8 (32/64 bits)
Say goodbye to the days of slow flatbed scanning! Scanning pictures and other memorabilia is now fast and easy - with great profit potential - thanks to the Kodak Picture Saver Scanning Systems PS50. Just think - while it used to take one to two minutes to scan a single photo on a flatbed, you can now scan up to 85 photos in just one minute! And the image quality and automatic enhancements are simply dazzling, thanks to easy-to-use, intuitive Kodak picture saver scanning software.
  • Gentle photo handling
    With the Kodak gentle photo separation module, the specially designed transport treats every photo with extra-gentle care.
  • Kodak Perfect Touch technology built in
    For bright, vibrant colors and rich detail in addition to the ability to improve contrast and color balance and correct red eye.
  • Flexible workflow
    Start, stop, or reopen an existing scanning job at any point in the capture-edit-output cycle; this gives you the flexibility.
  • Automatic image straightening
    It delivers auto deskew for proper image alignment.
  • Software-based image cleaning
    Reduce artifacts from environmental factors, such as dust.
Kodak Picture Saver Scanning System PS50 - document scanner - desktop - USB 2.0
Document scanner - desktop
Interface Type
USB 2.0
Scanning Sensor Type
Dual CCD
Light Source
Dual LED
Max Supported Document Size
215 x 863 mm
Input Type
Grayscale / Color Depth
48-bit colour
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
50 ppm (mono) / 50 ppm (colour)
Max Document Size
302 mm x 461 mm
Automatic Duplexing
Supported Document Type
Plain paper
Document Feeder Type
Automatic
Document Storage Capacity
50 sheets
Microsoft Windows Vista (32/64 bits) SP2, Microsoft Windows XP SP3, Microsoft Windows XP 64-bit Edition SP2, Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits)
33 cm x 16.2 cm x 24.6 cm
5.5 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 2.0
215 x 863 mm
Scanner
Input Type
Grayscale Depth (External)
Colour Depth
48-bit colour
Colour Depth (External)
Optical Resolution
600 dpi x 600 dpi
Automatic Duplexing
Dual CCD
Bulb / Light Source Type
Dual LED
Max Document Scan Speed B/W
50 ppm
Max Document Scan Speed Colour
50 ppm
Scanner Speed Details
50 ppm - landscape - 10x15cm - 300 dpi
Scanner Features
Color Dropout, Automatic Image Orientation, automatic colour detection, Auto Crop, iThresholding, Perfect Page, dual-stream scanning, adaptive threshold processing, Deskew
TWAIN
Media Handling
Max Document Size
302 mm x 461 mm
Plain paper
Automatic
50 sheets
USB 2.0
Dust cover
GOST, CISPR 22 Class B, cUL, EN 61000-3-3, EN55024, EN55022 Class B, CCC, FCC CFR47 Part 15 B, S Mark, GB 4943, GB 9254 Class B, GB 17625.1, CAN/CSA C22.2 No. 60950-1-07, AS/NZS, EN 60950-1 Second Edition, IEC 60950-1 Second Edition, ICES-003 issue 4 Class B, UL 60950-1-07
ENERGY STAR Certified
External power adapter
Power Consumption Operational (Standby)
32 Watt (0.35 Watt)
Software Included
Drivers & Utilities, KODAK Smart Touch
33 cm
16.2 cm
24.6 cm
5.5 kg
10 °C
35 °C
15 - 76%
