Kodak I4850 A4 Document Scanner
Quicklinx: CCMZWS00 Mfr#: 1738764
  • Windows 8.1 (32/64 bits)
  • Windows 8 (32/64 bits)
Busy mailrooms, production departments and service bureaus have relied on KODAK i4000 Series Scanners for years to deliver a valuable combination of quality, productivity, and affordability. They're a great choice for plowing through hours of uninterrupted scanning.
Speed through huge jobs with time-saving features and the muscle to handle up to 125,000 scans a day. Larger interactive control panel lets operators do more without leaving the scanner for the host PC. Manage multi-feeds, avoid document damage and reduce the need for rescans with Intelligent Document Protection and auto image rotation. Control the most complicated workflows on the fly with advanced barcode reading.
  • A fresh take on great performance
  • Minimize interruptions, maximize productivity
  • Image quality that's close to perfect
    Get crisp, clear images even with challenging originals, thanks to the latest Perfect Page image processing technology. Stay productive with improved document feeding Spend less time loading documents and more time getting your work done thanks to a 500-sheet input tray and controlled stacking technology. Easily scan a mixture of documents of different sizes and thicknesses - from business cards to file folders.
  • It's easier than ever to take control
    Easily eliminate interruptions in big multi-batch jobs with simple patch counting and front-side imprinting technology.
Kodak i4850 - document scanner - desktop - USB 3.0
Document scanner - desktop
Interface Type
USB 3.0
Scanning Sensor Type
CCD
Light Source
White LED array
Max Supported Document Size
304.8 x 5300 mm
Input Type
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
160 ppm (mono) / 160 ppm (colour)
Max Document Size
304.8 mm x 5300 mm
Supported Document Type
Plain paper
Document Feeder Type
Automatic
Document Storage Capacity
500 sheets
Duty Cycle
150000 scans per day
Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Windows 8.1 (32/64 bits), Ubuntu 14.04 LTS, Ubuntu 14.04 LTS (64-bit)
48.9 cm x 46.73 cm x 34.79 cm
30.4 kg
Environmental Standards
ENERGY STAR Qualified
90 days warranty
Interface Type
USB 3.0
304.8 x 5300 mm
Scanner
Input Type
Optical Resolution
600 dpi x 600 dpi
CCD
Bulb / Light Source Type
White LED array
Max Document Scan Speed B/W
160 ppm
Max Document Scan Speed Colour
160 ppm
Duty Cycle
Scanner Speed Details
160 ppm - landscape B&W - 200 dpi , 160 ppm - landscape colour - 300 dpi
Scanner Features
Multi Color Dropout, Automatic Image Orientation, iThresholding, Perfect Page, dual-stream scanning, Punch Hole Removal, Intelligent Document Protection, Intelligent Imprinting
TWAIN, ISIS, WIA
Media Handling
Max Document Size
304.8 mm x 5300 mm
Plain paper
Automatic
500 sheets
Interfaces Details
USB 3.0 - Type B
ENERGY STAR Certified
Internal power supply
Power Consumption Operational (Standby)
130 Watt
Power Consumption Stand by
1.5 Watt
Power Consumption Sleep
0.5 Watt
Software Included
KODAK Capture Pro Software Limited Edition
48.9 cm
46.73 cm
34.79 cm
30.4 kg
Limited warranty - 90 days - on-site
Sound Emission
63 dBA
