The Kodak i3000 series scanner is purpose-built to deliver consistent throughput and minimize downtime for your office. It is loaded with impressive imaging functionality for on boarding of information, and intelligent document protection to defend against damaged documents and lost data. This A3 rotary scanner can take on virtually any challenge while taking up less space on your desk - making it the perfect fit for any business that doesn't have a second to waste.
Missions accomplished
The Kodak i3000 series delivers consistently high throughput. Whether you're scanning in color or black and white, at 300 dpi, images, text or mixed-size documents - it doesn't matter, it just gets done. -
Give productivity a major lift
Stack up the work. With a 250-sheet feeder/elevator you can neatly and efficiently scan large or small batches with ease. The design ensures continuous throughput with rapid-fier scanning and less risk of jamming. -
Tear through work, not paper
Intelligent document protection is on duty for every document you scan. So scan fearlessly, with the assurance that your documents - and the information they contain - are protected. -
Better than ever
Kodak's Perfect Page technology optimizes image quality and intelligently manages a host of image processing tasks. It all happens automatically, with every scan. -
Intelligent by design
Scanning is really only half the story. Configuring image profiles, defining job names and file destinations, and distributing information is truly crucial. That's where Kodak's Smart Touch functionality takes over. It streamlines repetitive tasks like filing to your server, simplifies distribution of content, and makes access to your data easy, whether you're in the office or out on the road. -
Built to meet the demands of today and the rigors of tomorrow
Make no mistake, these scanners are made to last. Designed to impress your most experienced employees and make life easier for workers who are just getting started. When it comes to getting work done day after day, depend on scanners that truly deliver. -
Flexible input for inflexible documents
Some contracts are not just unbreakable, they're unbendable, too. This bypasses rotary scanning, enabling you to feed thick or exceptionally long documents right through.
- Kodak i3400 - document scanner - desktop - USB 2.0
- Document scanner - desktop
- Interface Type
- USB 2.0
- Scanning Sensor Type
- Dual CCD
- Light Source
- Dual LED
- Max Supported Document Size
- 304.8 x 4064 mm
- Input Type
- Grayscale / Color Depth
- 48-bit colour
- Grayscale / Color Depth (External)
- 8-bit (256 grey levels) / 24-bit (16.7 million colours)
- Optical Resolution
- 600 dpi x 600 dpi
- Interpolated Resolution
- 1200 dpi x 1200 dpi
- Max Document Scan Speed
- 80 ppm (mono) / 80 ppm (colour)
- Max Document Size
- 304.8 mm x 4064 mm
- Automatic Duplexing
- Supported Document Type
- Plain paper
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 250 sheets
- Duty Cycle
- 20000 scans per day
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Microsoft Windows Vista (32/64 bits) SP2, Ubuntu 10.04, Microsoft Windows 7 (32/64 bits) SP1, Microsoft Windows XP (32/64 bits) SP3, Windows 8 (32/64 bits)
- 43.18 cm x 37.1 cm x 23.75 cm
- 15.8 kg
- Environmental Standards
- ENERGY STAR Qualified
- Interface Type
- USB 2.0
- 304.8 x 4064 mm
Scanner
- Input Type
- Grayscale Depth (External)
- Colour Depth
- 48-bit colour
- Colour Depth (External)
- 24-bit (16.7 million colours)
- 600 dpi x 600 dpi
- Dual CCD
- Bulb / Light Source Type
- Dual LED
- Max Document Scan Speed B/W
- 80 ppm
- Max Document Scan Speed Colour
- 80 ppm
- Duty Cycle
- Scanner Speed Details
- 80 ppm - landscape B&W - Letter - 300 dpi , 160 ipm - duplex - landscape B&W - Letter - 300 dpi , 80 ppm - landscape greyscale - Letter - 300 dpi , 160 ipm - duplex - landscape greyscale - Letter - 300 dpi , 80 ppm - landscape colour - Letter - 300 dpi , 160 ipm - duplex - landscape colour - Letter - 300 dpi
- Scanner Features
- Color Dropout, Ultrasonic Double Feed Detection, Automatic Image Orientation, automatic colour detection, Auto Crop, iThresholding, Perfect Page, dual-stream scanning, touch screen LCD display, adaptive threshold processing, image merge, auto brightness, Deskew, Blank Page Detection
- TWAIN, ISIS, WIA
Media Handling
- Max Document Size
- Plain paper
- Automatic
- 250 sheets
- Interfaces Details
- USB 2.0
- Cables Included
- 1 x USB cable
- UL, TUV GS, C-Tick, cUL, EN 61000-3-3, EN55024, CISPR 22, EN55022 Class B, ICES-003 Class B, CCC, UL 60950-1, IEC 60950-1, EN 60950-1, FCC CFR47 Part 15 B, S Mark, BSMI CNS 14336, GB 4943, GB 9254 Class B, GB 17625.1, CAN/CSA C22.2 No. 60950-1-07, AS/NZS, VCCI Class B
- EPEAT Compliant
- EPEAT Bronze
- ENERGY STAR Certified
- Power Device
- External power adapter
- Voltage Required
- Power Consumption Operational (Standby)
- 75 Watt (0.5 Watt)
- Software Included
- Drivers & Utilities, KODAK Capture Desktop Software, KODAK Smart Touch
- OS Required
- System Requirements Details
- Core 2 Duo RAM 3 GB
- 43.18 cm
- 37.1 cm
- 23.75 cm
- 15.8 kg
- 15 °C
- 35 °C
- 15 - 76%
- Sound Emission
- 40 dBA
