Kodak i1150WN A4 Colour Document Scanner
Quicklinx: CCMGWS00 Mfr#: 1131176
The wireless and network KODAK SCANMATE i1150WN scanner makes life a lot easier and more efficient for any business. Scan documents straight to your mobile device and speed up life. Or share one scanner with many users in a tight space or an open collaboration work area. Welcome to an exciting world of flexible, versatile, cost effective, convenient and stress-free scanning.
  • Simple network set up
    Just print and scan the encrypted QR code created during the easy setup process.
  • Simple to use
    An intuitive display panel makes scanning tasks quick and easy.
  • Easy to share
    More than one person can use a wireless network scanner. They're great for collaborative work spaces or small workgroups and they don't have cables!
  • Easy to move around
    Wireless network scanners are portable and compact.
  • Scan to any device
    Capture information to your computer, mobile or tablet.
  • Cable free
    The clue is in the name. They're wireless, which means they are neat and tidy with no cable clutter.
  • Top quality imaging
    Scan everything from ID and credit cards to a wide range of business documents in high quality resolution with the Perfect Page image enhancement technology and reliable document feeding.
  • IT friendly
    Integrates easily using standard drivers to give you the convenience of wireless scanning with your existing business applications.
  • Simply secure
    Set and control your own level of security with ease.
Kodak i1150WN - document scanner - desktop - USB 2.0, LAN, Wi-Fi(n)
Document scanner - desktop
Interface Type
Scanning Sensor Type
CMOS / CIS
Light Source
Dual LED
Additional Functions
Scan to print, scan to cloud, scan to smart devices, scan to FTP, scan to file, scan to folder
Max Supported Document Size
215 x 355.6 mm
Input Type
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
40 ppm (mono) / 40 ppm (colour)
Max Document Size
215 mm x 355.6 mm
Supported Document Type
Plain paper, business card, plastic card, embossed card
Document Feeder Type
Automatic
Document Storage Capacity
75 sheets
Duty Cycle
3000 scans per day
Microsoft Windows Server 2008 x64 Edition, Microsoft Windows Server 2012 x64 Edition, Microsoft Windows Vista / 7 / 8 / 8.1 / 10 (32/64 bits)
33 cm x 16.2 cm x 24.6 cm
3.2 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
215 x 355.6 mm
Scanner
Input Type
Optical Resolution
600 dpi x 600 dpi
CMOS / CIS
Bulb / Light Source Type
Dual LED
Max Document Scan Speed B/W
40 ppm
Max Document Scan Speed Colour
40 ppm
Barcodes
UPC-A, UPC-E, Codabar, Code 128, Code 3 of 9, Interleaved 2 of 5, PDF417, EAN-8, EAN-13
Duty Cycle
3000 scans per day
Scanner Speed Details
40 ppm - portrait B&W - 200 dpi , 40 ppm - portrait greyscale - 200 dpi , 40 ppm - portrait colour - 200 dpi , 40 ppm - portrait B&W - 300 dpi , 40 ipm - portrait greyscale - 300 dpi , 40 ipm - portrait colour - 300 dpi
Scanner Features
Intelligent Document Protection
Scan File Formats
BMP, JPEG, PNG, TIFF
TWAIN, ISIS, WIA
Media Handling
Max Document Size
215 mm x 355.6 mm
Automatic
75 sheets
Interfaces Details
USB 2.0 , LAN
ENERGY STAR Certified
Internal power supply
Power Consumption Operational (Standby)
21 watt
Power Consumption Stand by
14 watt
Power Consumption Sleep
0.5 watt
33 cm
16.2 cm
24.6 cm
3.2 kg
