Kodak ALARIS S2080W Scanner
Quicklinx: DKCRWS00 Mfr#: 1015189
Type: Document scanner
Form Factor: Desktop
Max Paper Size: 216 x 3000 mm
Interface: LAN, USB 3.1 Gen 1, Wi-Fi(n)
  • Windows 8 (32/64 bits)
  • Windows 8.1 (32/64 bits)
Hurry, only 1 left in stock!
£868.97 ex VAT
£1,042.76 inc VAT
The Alaris S2080w scanners let your team capture the information needed to move work forward. Individual user profiles show personalized destinations, so multiple people can share one device.
Alaris S2080w - document scanner - desktop - LAN, Wi-Fi(n), USB 3.1 Gen 1
Document scanner - desktop
Interface Type
Scan Element Type
Dual CIS
Light Source
RGB LED array
Max Supported Document Size
216 x 3000 mm
Input Type
Grayscale / Color Depth
8-bit (256 grey levels)
Grayscale / Color Depth (External)
24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
80 ppm (mono) / 80 ppm (colour)
Max Document Size
216 mm x 3000 mm
Supported Document Type
Plain paper, business card
Document Feeder Type
Automatic
Document Storage Capacity
80 sheets
Duty Cycle
8000 scans per day
Microsoft Windows Server 2008 x64 Edition, Ubuntu, Microsoft Windows 7 (32/64 bits) SP1, Windows 8 (32/64 bits), Microsoft Windows Server 2012 x64 Edition, Windows 8.1 (32/64 bits), Windows 10 (32/64 bits)
31.2 cm x 20.4 cm x 18.25 cm
3.3 kg
Environmental Standards
ENERGY STAR Qualified
3-year warranty
Interface Type
216 x 3000 mm
Scanner
Input Type
Grayscale Depth
Colour Depth (External)
Optical Resolution
600 dpi x 600 dpi
Scan Element Type
Dual CIS
Bulb / Light Source Type
RGB LED array
Max Document Scan Speed B/W
80 ppm
Max Document Scan Speed Colour
80 ppm
Duty Cycle
8000 scans per day
Scanner Features
Barcode Detection, automatic colour detection, Auto Crop, auto white balance, dual-stream scanning, image merge, 3.5" touch screen LCD display
TWAIN, ISIS, WIA, SANE
Media Handling
Max Document Size
216 mm x 3000 mm
Automatic
80 sheets
USB 3.1 Gen 1 , LAN
TUV GS, BSMI, EN 60950, CCC, UL 60950-1, FCC CFR47 Part 15 B, EN 55024:2010, EN 55022:2010, AS/NZS CISPR22:2009+A1:2010, CAN/CSA-CISPR 22-10, GB 9254-2008 Class B, IEC60950-1:2005+A1, CNS13438:2006 Class B, GB 4943.1-2011, CNS 14336-1, CAN/CSA-C22.2 No. 60950-1-07+A1:2011
ENERGY STAR Certified
Internal power supply
Power Consumption Operational (Standby)
36 Watt
Power Consumption Stand by
5 Watt
Power Consumption Sleep
0.5 Watt
31.2 cm
20.4 cm
18.25 cm
3.3 kg
Limited warranty - replacement - 3 years
10 °C
35 °C
15 - 80%
Interface: LAN
Interface: USB 3.1 Gen 1
Interface: Wi-Fi(n)
Brand: Kodak
Price Range Ex VAT: 750 - 1000
