The Alaris S2080w scanners let your team capture the information needed to move work forward. Individual user profiles show personalized destinations, so multiple people can share one device.
Intuitive user display
Start up faster and stay productive with ease-of-use features. Install preconfigured settings in seconds using the award-winning Easy Setup feature. The intuitive color displays make scanning quick and easy. Save up to 20 job setups and destinations with one-touch scanning. -
Active Feed technology
Keep working without worrying about jams, thanks to a paper path built for exceptional reliability. Active Feed automatically jogs pages to avoid misfeeds. Maintain maximum uptime with SurePath Paper Handling. Controlled Output stacking neatly places pages in the output tray. -
Wi-Fi and Ethernet connectivity
Place the scanner wherever needed, with or without the need of a USB cable. Wi-Fi and Ethernet connectivity allow you to connect the scanner to your office network to suit your business needs. Secures your scans over a network with HTTPS, WPA Enterprise, and TLS encryption standards. -
Embedded Image Processing
Save money at all steps in the scanning process, with innovation that takes out overhead costs. Embedded Image Processing delivers crisp, high-quality images at full speed without depending on a super-powered PC. Intelligent features help reduce manual pre- and post-scan tasks. -
Alaris OCR technology
Get the right information the first time, with Optical Character Recognition read rates that are 10% more accurate than competitive devices. Perfect Page technology delivers superior image quality with 30+ enhancements automatically for more accurate image extraction. -
Integrate directly into business processes
Deliver information exactly where it needs to go, in the right format. Your documents can go anywhere you need: local or network folders, FTP, cloud destinations like SharePoint, or other ECM systems. -
Ready for passports or small delicate documents
The S2000 Series is designed to "dock" on top of the Kodak Passport Flatbed Accessory, offering a quick and easy solution for scanning passports, ID cards and other small, fragile documents. You don't need another power cord or USB port on your host PC. Thanks to seamless TWAIN and ISIS-driver integration there is no need to use multiple scanner drivers. -
Fit into any business environment
Integrates easily with existing business applications using standard drivers. Or use the RESTful Web API to integrate your business app or application to the scanner directly without the need for a driver.
- Kodak S2080w - document scanner - desktop - LAN, Wi-Fi(n), USB 3.1 Gen 1
- Document scanner - desktop
- Interface Type
- Scanning Sensor Type
- Dual CIS
- Light Source
- RGB LED array
- Max Supported Document Size
- 216 x 3000 mm
- Input Type
- Grayscale / Color Depth
- 8-bit (256 grey levels)
- Grayscale / Color Depth (External)
- 24-bit (16.7 million colours)
- Optical Resolution
- 600 dpi x 600 dpi
- Max Document Scan Speed
- 80 ppm (mono) / 80 ppm (colour)
- Max Document Size
- 216 mm x 3000 mm
- Supported Document Type
- Plain paper, business card
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 80 sheets
- Duty Cycle
- 8000 scans per day
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Microsoft Windows Server 2008 x64 Edition, Ubuntu, Microsoft Windows 7 (32/64 bits) SP1, Windows 8 (32/64 bits), Microsoft Windows Server 2012 x64 Edition, Windows 8.1 (32/64 bits), Windows 10 (32/64 bits)
- 31.2 cm x 20.4 cm x 18.25 cm
- 3.3 kg
- Environmental Standards
- ENERGY STAR Qualified
- 5-year warranty
- Interface Type
- 216 x 3000 mm
Scanner
- Input Type
- Grayscale Depth
- Colour Depth (External)
- 600 dpi x 600 dpi
- Dual CIS
- Bulb / Light Source Type
- RGB LED array
- Max Document Scan Speed B/W
- 80 ppm
- Max Document Scan Speed Colour
- 80 ppm
- Duty Cycle
- Scanner Features
- Barcode Detection, automatic colour detection, Auto Crop, auto white balance, dual-stream scanning, image merge, 3.5" touch screen LCD display
- TWAIN, ISIS, WIA, SANE
Media Handling
- Max Document Size
- 216 mm x 3000 mm
- Automatic
- 80 sheets
- Interfaces Details
- USB 3.1 Gen 1 , LAN
- TUV GS, BSMI, EN 60950, CCC, UL 60950-1, FCC CFR47 Part 15 B, EN 55024:2010, EN 55022:2010, AS/NZS CISPR22:2009+A1:2010, CAN/CSA-CISPR 22-10, GB 9254-2008 Class B, IEC60950-1:2005+A1, CNS13438:2006 Class B, GB 4943.1-2011, CNS 14336-1, CAN/CSA-C22.2 No. 60950-1-07+A1:2011
- ENERGY STAR Certified
- Power Device
- Internal power supply
- Voltage Required
- Power Consumption Operational (Standby)
- 36 Watt
- Power Consumption Stand by
- 5 Watt
- Power Consumption Sleep
- 0.5 Watt
- OS Required
- 31.2 cm
- 20.4 cm
- 18.25 cm
- 3.3 kg
- Advanced Exchange Service - Next Business Day Onsite Support - 5 years
- 10 °C
- 35 °C
- 15 - 80%
