Kodak ALARIS S2060W Scanner
Quicklinx: DKCPWS00 Mfr#: 1015114
Type: Document scanner
Form Factor: Desktop
Max Paper Size: 216 x 3000 mm
Interface: LAN, USB 3.1 Gen 1, Wi-Fi(n)
£794.49 ex VAT
£953.38 inc VAT
Digital transformation starts with information capture. Imagine document scanning that speeds and simplifies your business processes. The Alaris S2000 series scanners are built to let users capture information anywhere, with superior image quality and data accuracy. It's the perfect solution when you need to get information into your business processes quickly.
  • Faster, easier scanning leaves more time for business
    The Alaris S2000 series scanners enhance your productivity by handling more of the work traditionally done by people, computers and mobile devices.
  • Document and information handling you can trust
    Ensure reliable data quality at the point of capture through a combined approach of hardware and software technologies.
  • Capture that streamlines your business processes
    Document capture integrates smoothly and conveniently into your normal workflow.
  • Easy to set up, easy to use
    An intuitive color interface and predefined job setups simplify the lives of users and network administrators.
  • Information capture that evolves with your business
    The S2000 series scanners are designed to fit seamlessly into your business environment and adapt as your needs change.
Alaris S2060w - document scanner - desktop - LAN, Wi-Fi(n), USB 3.1 Gen 1
Document scanner - desktop
Interface Type
Scan Element Type
Dual CIS
Light Source
RGB LED array
Max Supported Document Size
216 x 3000 mm
Input Type
Grayscale / Color Depth
8-bit (256 grey levels)
Grayscale / Color Depth (External)
24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
60 ppm (mono) / 60 ppm (colour)
Max Document Size
216 mm x 3000 mm
Supported Document Type
Plain paper, business card
Document Feeder Type
Automatic
Document Storage Capacity
80 sheets
Duty Cycle
7000 scans per day
31.2 cm x 20.4 cm x 18.25 cm
3.3 kg
Interface Type
216 x 3000 mm
Scanner
Input Type
Grayscale Depth
Colour Depth (External)
Optical Resolution
600 dpi x 600 dpi
Scan Element Type
Dual CIS
Bulb / Light Source Type
RGB LED array
Max Document Scan Speed B/W
60 ppm
Max Document Scan Speed Colour
60 ppm
Duty Cycle
7000 scans per day
Scanner Features
Automatic colour detection, auto white balance, dual-stream scanning, image merge
TWAIN, ISIS, WIA, SANE
Media Handling
Max Document Size
216 mm x 3000 mm
Automatic
80 sheets
USB 3.1 , LAN
TUV GS, BSMI, EN 60950, CCC, UL 60950-1, FCC CFR47 Part 15 B, EN 55024:2010, EN 55022:2010, AS/NZS CISPR22:2009+A1:2010, CAN/CSA-CISPR 22-10, GB 9254-2008 Class B, IEC60950-1:2005+A1, CNS13438:2006 Class B, GB 4943.1-2011, CNS 14336-1, CAN/CSA-C22.2 No. 60950-1-07+A1:2011
Internal power supply
Power Consumption Operational (Standby)
36 Watt
Power Consumption Stand by
5 Watt
Power Consumption Sleep
0.5 Watt
31.2 cm
20.4 cm
18.25 cm
3.3 kg
10 °C
35 °C
15 - 80%
Interface: LAN
Interface: USB 3.1 Gen 1
Interface: Wi-Fi(n)
Brand: Kodak
Price Range Ex VAT: 750 - 1000
