Kodak ALARIS S2060W Scanner
Quicklinx: DKCPWS00 Mfr#: 1015114
Type: Document scanner
Form Factor: Desktop
Max Paper Size: 216 x 3000 mm
Interface: Wi-Fi(n), LAN, USB 3.1 Gen 1
Compatibility: PC
Hurry, only 1 left in stock!
£829.79 ex VAT
£995.74 inc VAT
The Kodak-Alaris S2000 A4 scanners are built to let anyone capture information anywhere, with superior image quality and data accuracy. It’s the perfect solution when you need to get information into your business fast.
Embedded Image Processing delivers crisp, high-quality images without depending on your PC.
Active Feed technology perfectly aligns pages to avoid misfeeds and multifeeds.
Perfect Page optimizes image quality on every page for accurate information extraction.
Can be paired with the excellent Alaris Passport Flatbed Accessory, for simple and high-quality scans of legal-size documents including passports.
The S2060W scans at speeds of up to 60 pages per minute, whilst the S2080w scans at speeds of up to 80 pages per minute. Crucially, these scanners are wifi and network compatible, to allow for even greater efficiency and access for you and your staff in the office. The scanners have a 3.5" colour display, where jobs can be customised and selected quickly, meaning that a scanned document can be shared to a selected destination within seconds.
In addition, the range can be purchased with Alaris Simple Invoicing Software suite, allowing for effective invoice procesing for your small business.
Contact Us for pricing and installation.
Kodak Alaris Perfect Page Software
Perfect Page is an Image Enhancement Software tool, produced by Kodak-Alaris. It is bundled as standard, with all Kodak-Alaris scanners, and is designed to improve visibility of scanned media. This, in turn, will save your business time during the scanning process, but also when retrieving digital documents. Perfect Page features advanced image enhancement features, such as:
De-skew and auto-cropping
Auto-Orientation
Auto-Brightness
Sharpening
Intelligent Background Colour Smoothing
Streak Removal
Noise Reduction
The Kodak Alaris S2060W scanner can be tethered to the Kodak Alaris A3 Flatbed Scanner accessory for A3 scanning of fragile documents, large-scale drawing plans, photographs, artwork etc.
  • Intuitive user display
    Start up faster and stay productive with ease-of-use features. Install preconfigured settings in seconds. The intuitive color displays make scanning quick and easy. Save up to 20 job setups and destinations with one-touch scanning.
  • Active Feed technology
    Keep working without worrying about jams, thanks to a paper path built for exceptional reliability. Active Feed automatically jogs pages to avoid misfeeds.
  • Wi-Fi and Ethernet connectivity
    Place the scanner wherever needed, with or without the need of a USB cable. Wi-Fi and Ethernet connectivity allows you to connect the scanner to your office network to suit your business needs.
  • Embedded image processing
    Save money at all steps in the scanning process, with innovation that takes out overhead costs. Embedded image processing delivers crisp, high-quality images at full speed without depending on a super-powered PC.
  • Optical character recognition
    Get the right information the first time, with optical character recognition read rates that are more accurate. Perfect Page technology delivers superior image quality with 30+ enhancements automatically for more accurate image extraction.
  • Integrate directly into business processes
    Deliver information exactly where it needs to go, in the right format. Your documents can go anywhere you need: local or network folders, FTP, or cloud destinations.
Kodak S2060w - document scanner - desktop - LAN, Wi-Fi(n), USB 3.1 Gen 1
Document scanner - desktop
Interface Type
Scanning Sensor Type
Dual CIS
Light Source
RGB LED array
Max Supported Document Size
216 x 3000 mm
Input Type
Grayscale / Color Depth
8-bit (256 grey levels)
Grayscale / Color Depth (External)
24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
60 ppm (mono) / 60 ppm (colour)
Max Document Size
216 mm x 3000 mm
Supported Document Type
Plain paper, business card
Document Feeder Type
Automatic
Document Storage Capacity
80 sheets
Duty Cycle
7000 scans per day
31.2 cm x 20.4 cm x 18.25 cm
3.3 kg
5-year warranty
Interface Type
216 x 3000 mm
Scanner
Input Type
Grayscale Depth
Colour Depth (External)
Optical Resolution
600 dpi x 600 dpi
Dual CIS
Bulb / Light Source Type
RGB LED array
Max Document Scan Speed B/W
60 ppm
Max Document Scan Speed Colour
60 ppm
Duty Cycle
7000 scans per day
Scanner Features
Automatic colour detection, auto white balance, dual-stream scanning, image merge
TWAIN, ISIS, WIA, SANE
Media Handling
Max Document Size
216 mm x 3000 mm
Automatic
80 sheets
Interfaces Details
USB 3.1 , LAN
TUV GS, BSMI, EN 60950, CCC, UL 60950-1, FCC CFR47 Part 15 B, EN 55024:2010, EN 55022:2010, AS/NZS CISPR22:2009+A1:2010, CAN/CSA-CISPR 22-10, GB 9254-2008 Class B, IEC60950-1:2005+A1, CNS13438:2006 Class B, GB 4943.1-2011, CNS 14336-1, CAN/CSA-C22.2 No. 60950-1-07+A1:2011
Internal power supply
Power Consumption Operational (Standby)
36 Watt
Power Consumption Stand by
5 Watt
Power Consumption Sleep
0.5 Watt
31.2 cm
20.4 cm
18.25 cm
3.3 kg
Advanced Exchange Service - Next Business Day Onsite Support - 5 years
10 °C
35 °C
15 - 80%
Interface: Wi-Fi(n)
Interface: LAN
Interface: USB 3.1 Gen 1
Compatibility: PC
Brand: Kodak
Price Range Ex VAT: £750 - £1000
