Kodak ALARIS S2050 Scanner
Quicklinx: DKCMWS00 Mfr#: 1014968
Type: Document scanner
Form Factor: Desktop
Max Paper Size: 216 x 3000 mm
Interface: USB 3.1
  • Windows 8.1 (32/64 bits)
  • Windows 8 (32/64 bits)
£464.81 ex VAT
£557.77 inc VAT
Kodak ALARIS S2050 Scanner. Maximum scan size: 216 x 3000 mm, Optical scanning resolution: 600 x 600 DPI, Input colour depth: 30 bit. Scanner type: ADF scanner, Colour of product: Black, White, Display: LCD. Sensor type: Dual CIS, Daily duty cycle (max): 5000 pages, Light source: RGB LED. Standard input capacity: 80 sheets, Auto document feeder (ADF) input capacity: 80 sheets. Maximum ISO A-series paper size: A3, Scanning media types supported: Business Card, Envelopes, Plain paper, Plastic Card, Post Card(JPN), Recycled paper, Thick paper,..., Maximum scan area (ADF): 215 x 155.6 mm
  • Embedded Image Processing
    Save money at all steps in the scanning process, with innovation that takes out overhead costs. Embedded Image Processing delivers crisp, high-quality images at full speed without depending on a super-powered PC. Intelligent features help reduce manual pre- and post-scan tasks.
  • Intuitive user display
    Start up faster and stay productive with ease-of-use features. Install preconfigured settings in seconds using the award-winning Easy Setup feature. The intuitive color displays make scanning quick and easy. Save up to 20 job setups and destinations with one-touch scanning.
  • Active Feed Technology
    Keep working without worrying about jams, thanks to a paper path built for exceptional reliability. Active Feed automatically jogs pages to avoid misfeeds. Maintain maximum uptime with SurePath Paper Handling. Controlled Output stacking neatly places pages in the output tray.
  • Optical Character Recognition
    Get the right information the first time, with OCR read rates that are 10% more accurate than competitive devices. Perfect Page technology delivers superior image quality with 30+ enhancements automatically for more accurate image extraction.
Alaris S2050 - document scanner - desktop - USB 3.1
Document scanner - desktop
Interface Type
USB 3.1
Light Source
RGB LED array
Max Supported Document Size
216 x 3000 mm
Input Type
Grayscale / Color Depth
8-bit (256 grey levels)
Grayscale / Color Depth (External)
24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
50 ppm (mono) / 50 ppm (colour)
Max Document Size
216 mm x 3000 mm
Supported Document Type
Plain paper, business card
Document Feeder Type
Automatic
Document Storage Capacity
80 sheets
Duty Cycle
5000 scans per day
Ubuntu, Microsoft Windows 7 (32/64 bits) SP1, Windows 8 (32/64 bits), Windows 8.1 (32/64 bits), Microsoft Windows Server 2008 (64-bits), Microsoft Windows Server 2012 (64-bit), Windows 10 (32/64 bits)
31.2 cm x 20.4 cm x 18.25 cm
7.2 kg
Interface Type
USB 3.1
216 x 3000 mm
Scanner
Input Type
Grayscale Depth
Colour Depth (External)
Optical Resolution
600 dpi x 600 dpi
Bulb / Light Source Type
RGB LED array
Max Document Scan Speed B/W
50 ppm
Max Document Scan Speed Colour
50 ppm
Duty Cycle
5000 scans per day
Scanner Features
Automatic colour detection, auto white balance, dual-stream scanning, image merge
TWAIN, ISIS, WIA
Media Handling
Max Document Size
216 mm x 3000 mm
Automatic
80 sheets
USB 3.1
TUV GS, BSMI, EN 60950, CCC, UL 60950-1, FCC CFR47 Part 15 B, EN 55024:2010, EN 55022:2010, AS/NZS CISPR22:2009+A1:2010, CAN/CSA-CISPR 22-10, GB 9254-2008 Class B, IEC60950-1:2005+A1, CNS13438:2006 Class B, GB 4943.1-2011, CNS 14336-1, CAN/CSA-C22.2 No. 60950-1-07+A1:2011
Internal power supply
Power Consumption Operational (Standby)
36 Watt
Power Consumption Stand by
0.5 Watt
System Requirements Details
Core i3 - 3.5 GHz - RAM 3.43 GB
31.2 cm
20.4 cm
18.25 cm
7.2 kg
10 °C
35 °C
15 - 80%
Interface: USB 3.1
Brand: Kodak
Price Range Ex VAT: 300 - 500
