Kodak A3 Size Flatbed Accessory
Quicklinx: 9KY7WS00 Mfr#: 1894351
Flexible freedom to scan exception documents, books and beyond
The Kodak Legal Size Flatbed Accessory and the Kodak A3 Size Flatbed Accessory—used in conjunction with a compatible Kodak Scanner—allow you to easily scan fragile or oversized documents, books, magazines, photo enlargements and more. All three flatbeds attach and detach in seconds, and can be easily stored away until needed again.
The Legal Size Flatbed also features book-edge scanning, allowing you to scan one page at a time and eliminate blurred or dark imaging in the "gutter" area of a book that sits fully opened on the glass platen.
Kodak A3 Flatbed Accessory - scanner dockable flatbed accessory
Scanner dockable flatbed accessory
Package Content
USB cable, power adapter
43.8 cm x 71.1 cm x 15.9 cm
10.8 kg
Supported Formats
A3 (297 x 420 mm), 297 x 432 mm, 304.8 x 457 mm
Alaris S2050, S2060w, S2070, S2080w, S3060; Kodak i3000, S2050, S2070, S2080w, S3060, S3100, S3100f, S3120 Max; S2000 Series S2050; Scan Station 730EX Plus
Package Content
Supported Formats
43.8 cm
71.1 cm
15.9 cm
10.8 kg
Alaris S2050, S2060w, S2070, S2080w, S3060 , Kodak i3000, S2050, S2070, S2080w, S3060, S3100, S3100f, S3120 Max , Kodak S2000 Series S2050 , Kodak Scan Station 730EX Plus
