ValueRAM is Kingston's value-priced line of industry-standard, generic memory intended for customers who have white box or generic computer systems, or who plan to purchase memory by specification. ValueRAM is designed to industry specs, is 100% tested and is available at competitively low prices.
- Kingston ValueRAM - DDR2 - module - 1 GB - DIMM 240-pin - 667 MHz / PC2-5300 - unbuffered
- Product Type
- Memory module
- Capacity
- 1 GB
- Memory Type
- DDR2 SDRAM - DIMM 240-pin
- Upgrade Type
- Generic
- Data Integrity Check
- Non-ECC
- Speed
- 667 MHz (PC2-5300)
- Latency Timings
- CL5
- Unbuffered
- Voltage
- 1.8 V
- Lead Plating
- Gold
- Limited lifetime warranty (Germany, Austria and France - 10 years)
- Designed For
- ASUS Commando Republic of Gamers, M2N, M2N32, N4L, P5WDG2; ECS 662/1066, 761, 945, 965, AMD480, AMD690, C19, C51, GeForce6100, K8M890, KA3, MCP55, NF650, NFORCE 570, NFORCE4M, NFORCE5M, P965, PA1, PF5, PF88, PN2, PX1, RC410L/800, RS482, RS485; Intel Desktop Board DG33, DP35
- Capacity
- 1 GB
- Upgrade Type
- Generic
- DRAM memory module
- Technology
- DDR2 SDRAM
- Form Factor
- DIMM 240-pin
- Module Height (inch)
- 1.25
- Speed
- Latency Timings
- CL5
- Non-ECC
- Unbuffered
- Module Configuration
- 128 x 64
- Chips Organization
- 64 x 8
- Voltage
- 1.8 V
- Lead Plating
- Gold
- Compatible Slots
- 1 x memory - DIMM 240-pin
- Designed For
- ABIT IL9 Pro-V, IP35, IP35 Pro, IP35-E, LG-80, NF-M2P, NF-M2SV , ASUS Commando Republic of Gamers, CROSSHAIR Republic of Gamers, M2N32 WS Professional, M2N32-SLI Deluxe, M2N32-SLI Premium, M2N-E, M2N-MX SE, M2N-Plus SLI, M2N-VM DH, M2N-X, M2S-X, N4L-VM DH, P5B-MX, P5B-Plus AiLifestyle Series, P5K AiLifestyle Series, P5K Deluxe/WiFi-AP AiLifestyle Series, P5K SE, P5K WS, P5K64 WS Workstation Series, P5KC AiLifestyle Series, P5K-E/WIFI-AP AiLifestyle Series, P5K-V, P5K-VM AiLifestyle Series, P5SD2-X SE, P5S-MX SE, P5VD2-VM SE, P5WDG2 WS AiLife Series, P5WDG2 WS Main Station Series, Striker Republic of Gamers Series , Biostar 945P-A7B, G965 Micro 775, NF61S Micro AM2, TA690G AM2, TF570 SLI, TF680I SLI DELUXE, TF7050-M2, TForce P965, TForce TF7050-M2, TForce4 U 775 , DFI INFINITY NF SLI-M2, Infinity nF Ultra II-M2, Infinity nF570 SLI-M2/G, INFINITY NF650i ULTRA-T2 , ECS 662/1066T-M, 662/1066T-M2, 761GXM-M, 945G-M2, 945G-M3, 945GZT-M, 965PLT-A, AMD480XM-A, AMD690GM-M2, C19-A SLI, C51GM-M, C51PVGM-M, GeForce6100SM-M, K8M890M-M, KA3 MVP, MCP55M-A, NF650iSLIT-A, NFORCE 570 SLIT-A, NFORCE4M-A, NFORCE5M-A, P965T-A, PA1 MVP, PF5 Extreme, PF88, PN2-SLI2+, PX1, RC410L/800-M, RS482-M, RS482M-M, RS485M-M , eMachines T5062, T5230 , EPoX EP-5P945 pro, EP-5P945-3, EP-5P945C, EP-5P945-J3, EP-5P965-J, EP-AF550G PRO, EP-AF570 PRO, EP-AGF6105-M , Fujitsu Premium D2156-A, Premium D2156-S, Premium D2178-A , Gigabyte GA-4KXSV-RH, GA-G33-DS3R, GA-MA69G-S3H, GA-MA78G-DS3H, GA-P35C-DS3R, GA-P35-DQ6, GA-P35-DS3, GA-P35-DS3P, GA-P35-DS3R, GA-P35-DS4, GA-P35-S3 , Intel Desktop Board DG33BU, DG33FB, DG33TL, DP35DP , MSI 945G Neo, 945G Neo 2, 945GCM5-F, 945GT Speedster-V, 946GZM, 946PLM, G33M-F, G33M-FI, K9AG Neo2-Digital, K9AG Neo-F, K9AGM2-F, K9N4 SLI, K9NGM, Media Live, P35 Diamond, P35 Neo Combo-F, P35 Neo2-FI, P35 Neo2-FIR, P35 Neo2-FR, P35 Neo-F, P35 Neo-FI, P35 Platinum, P4M900M2-F, P965 Neo 2 , SUPERMICRO C2SBA, C2SBA+, C2SBE, PDSMA+
Customer reviews
Write a review for the Kingston ValueRAM KVR667D2N5/1G ddr2 667 240pin dimm CL5 here!
Superb
Reviewed by Andy. Review Posted 02/02/2008
Put two of these into an MSI 945 board and installed Vista. The performance rating for the memory is 5.9 :)
Overall
Ease of use
Value for money
brilliant fantastic value
Reviewed by steffan thorning. Review Posted 11/01/2008
i got this awsome stick of ram when it was about £25 and now it is unbelievably even cheaper at around £15 . ive had no problems whatsoever and performance that is worth four times the value
Overall
Ease of use
Value for money
Works well in dual channel mode
Reviewed by Gerry. Review Posted 15/03/2007
Put in two of these (in dual channel mode) into a new Gigabyte AM2 board and it works faultlessly. Windows Vista reports a memory benchmark score of 5.8 (against a maximum of 6.0), so that can't be bad! And at under £45 each, having 2gb is now much more affordable.
Overall
Ease of use
Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
