Kingston ValueRAM Kingston 8GB 1600MHz DDR3L Non-ECC CL11 SODIMM 1.35V
Quicklinx: 985DWS00 Mfr#: KVR16LS11/8
Type: DDR3L SDRAM
Capacity: 8GB
Connection: SO-DIMM 204-pin
Speed: 1600MHz
Data Integrity: Non-ECC
12 in stock
£24.53 ex VAT
£29.43 inc VAT
Kingston Technology is the world's independent memory leader and is well-known for providing high quality memory products at an attractive price. Kingston ValueRAM is the best source for industry standard notebook memory, supplying the most reliable product, supported by an outstanding warranty and free tech support. ValueRAM notebook memory is validated on all of the notebook motherboard manufacturer's web sites including Asus, MSI, Gigabyte and more. Kingston Technology invests $millions to ensure the quality of its modules. Before shipping, all ValueRAM notebook memory is 100% production tested.
  • Quality and expertise
    With more than a quarter of a century of notebook memory expertise, Kingston has the knowledge and resources to support your needs. Kingston engineers use only the highest quality components on the market to ensure maximum performance and legendary Kingston reliability.
  • Performance
    Competitively priced ValueRAM notebook memory meets industry specifications and delivers award-winning performance.
Kingston ValueRAM - DDR3L - 8 GB - SO-DIMM 204-pin - unbuffered
RAM memory
8 GB
Memory Type
DDR3L SDRAM - SO-DIMM 204-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1600 MHz (PC3L-12800)
Latency Timings
CL11 (11-11-11)
Dual rank, On-Die Termination (ODT), unbuffered
Voltage
1.35 / 1.5 V
Lead Plating
Gold
8 GB
Upgrade Type
Generic
DRAM
DDR3L SDRAM
SO-DIMM 204-pin
Module Height (inch)
1.18
Speed
Latency Timings
CL11 (11-11-11)
Non-ECC
Module Configuration
1024 x 64
Chips Organization
512 x 8
Voltage
1.35 / 1.5 V
Lead Plating
Gold
Type: DDR3L SDRAM
Capacity: 8GB
Speed: 1600MHz
Registered/Buffered: Unbuffered
CAS Latency: CL11
Standard: PC3L-12800
Brand: Kingston ValueRAM
Price Range Ex VAT: 0 - 50
