Kingston ValueRAM Kingston 8GB 1333MHz DDR3 Non-ECC CL9 DIMM SR x8 (Kit of 2)
Quicklinx: CFTGWS00 Mfr#: KVR13N9S8HK2/8
ValueRAM is Kingston's value-priced line of industry-standard, generic memory intended for customers who have white box or generic computer systems, or who plan to purchase memory by specification. ValueRAM is designed to industry specifications tested, is 100% tested and is available at competitively low prices.
Kingston ValueRAM - DDR3 - kit - 8 GB: 2 x 4 GB - DIMM 240-pin - 1333 MHz / PC3-10600 - unbuffered
Memory kit
8 GB: 2 x 4 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1333 MHz (PC3-10600)
Latency Timings
CL9
Single rank, unbuffered
Voltage
1.5 V
Lead Plating
Gold
8 GB: 2 x 4 GB
Upgrade Type
Generic
DRAM memory kit
DDR3 SDRAM
DIMM 240-pin
Module Height (inch)
1.18
Speed
Latency Timings
CL9
Non-ECC
Module Configuration
512 x 64
Chips Organization
X8
Voltage
1.5 V
Lead Plating
Gold
Compatible Slots
2 x memory - DIMM 240-pin
