Kingston ValueRAM Kingston 4GB 1600MHZ DDR3L NON-ECC CL11 Memory Module
Quicklinx: 92L0WS00 Mfr#: KVR16LS11/4
Type: DDR3L SDRAM
Capacity: 4GB
Connection: SO-DIMM 204-pin
Speed: 800MHz
Data Integrity: Non-ECC
10 In Stock
£15.64 ex VAT
£18.76 inc VAT
ValueRAM is Kingston's value-priced line of industry-standard, generic memory intended for customers who have white box or generic computer systems, or who plan to purchase memory by specification. ValueRAM is designed to industry specifications tested, is 100% tested and is available at competitively low prices.
Kingston ValueRAM - DDR3L - module - 4 GB - SO-DIMM 204-pin / PC3-12800 - unbuffered
Memory module
4 GB
Memory Type
DDR3L SDRAM - SO-DIMM 204-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1600 MT/s (PC3-12800)
Latency Timings
CL11
Unbuffered
Voltage
1.35 V
Lead Plating
Gold
4 GB
Upgrade Type
Generic
DRAM memory module
DDR3L SDRAM
SO-DIMM 204-pin
Speed
Latency Timings
CL11
Non-ECC
Unbuffered
Module Configuration
512 x 64
Voltage
1.35 V
Lead Plating
Gold
Type: DDR3L SDRAM
Capacity: 4GB
Speed: 800MHz
Registered/Buffered: Unbuffered
CAS Latency: CL11
Standard: PC3-12800
Brand: Kingston ValueRAM
