Kingston ValueRAM 8GB (1 x 8GB) Notebook DDR3 1600MHz SODIMM Non-ECC CL11
Quicklinx: 8KYFWS00 Mfr#: KVR16S11/8
Type: DDR3 SDRAM
Capacity: 8GB
Connection: SO-DIMM 204-pin
Speed: 1600MHz
Data Integrity: Non-ECC
£32.73 ex VAT
£39.27 inc VAT
ValueRAM is Kingston's value-priced line of industry-standard, generic memory intended for customers who have white box or generic computer systems, or who plan to purchase memory by specification. ValueRAM is designed to industry specifications tested, is 100% tested and is available at competitively low prices.
Kingston ValueRAM - DDR3 - module - 8 GB - SO-DIMM 204-pin - 1600 MHz / PC3-12800 - unbuffered
Memory module
8 GB
Memory Type
DDR3 SDRAM - SO-DIMM 204-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1600 MHz (PC3-12800)
Latency Timings
CL11
Unbuffered
Voltage
1.5 V
Lead Plating
Gold
8 GB
Upgrade Type
Generic
DRAM memory module
DDR3 SDRAM
SO-DIMM 204-pin
Speed
Latency Timings
CL11
Non-ECC
Unbuffered
Module Configuration
1024 x 64
Voltage
1.5 V
Lead Plating
Gold
Compatible Slots
1 x memory - SO-DIMM 204-pin
Type: DDR3 SDRAM
Capacity: 8GB
Speed: 1600MHz
Registered/Buffered: Unbuffered
CAS Latency: CL11
Standard: PC3-12800
Brand: Kingston ValueRAM
