ValueRAM is Kingston's value-priced line of industry-standard, generic memory intended for customers who have white box or generic computer systems, or who plan to purchase memory by specification. ValueRAM is designed to industry specifications tested, is 100% tested and is available at competitively low prices.
This memory is designed for the following systems:
ABIT Fatal1ty AN9 32X Motherboard;
ABIT NI8 SLI Motherboard;
ABIT NI8-SLI GR Motherboard;
AOpen XC Cube EY945 Series;
AOpen XC Cube EZ945 Series;
ASUS M2N-E Motherboard;
ASUS M2N-SLI Deluxe Motherboard;
ASUS M2N32-SLI Deluxe Motherboard;
ASUS M2NPV-MX Motherboard;
ASUS M2NPV-VM Motherboard;
ASUS M2V Motherboard;
ASUS P5B Motherboard;
ASUS P5B Deluxe Motherboard;
ASUS P5LD2 / P5LD2 Deluxe Motherboard;
ASUS P5LD2 SE Motherboard;
ASUS P5LD2-V Motherboard;
ASUS P5LD2-VM Motherboard;
ASUS P5LD2-VM DH Motherboard;
ASUS P5MT / P5MT-M / P5MT/SCSI Motherboard;
ASUS P5MT-C Motherboard;
ASUS P5MT-S Motherboard;
ASUS P5RD2-VM Motherboard;
ASUS P5WD2 Motherboard;
ASUS P5WD2 Premium Motherboard;
ASUS P5WD2-E Premium Motherboard;
ASUS P5WDG2-WS Motherboard;
EliteGroup (ECS) C51GM-M Motherboard;
EliteGroup (ECS) K8M890M-M Motherboard;
EliteGroup (ECS) NForce4M-A Motherboard;
EliteGroup (ECS) RS485M-M Motherboard;
Foxconn Foxconn 975X7AA-8EKRS2H;
Foxconn Foxconn P9657AA-8EKRS2H;
Foxconn Foxconn P9657AA-8KS2H;
Gigabyte GA-8I955X Pro Motherboard;
Gigabyte GA-8I955X Royal Motherboard;
Gigabyte GA-G1975X Motherboard;
MSI 945G Neo Motherboard;
MSI 945G Neo-F Motherboard;
MSI 945G Platinum Motherboard;
MSI 945GM2 H-F Motherboard;
MSI 945GM2-F / 945GM2-FI / 945GM2-FR Motherboard;
MSI 945P Neo Motherboard;
MSI 945P Neo-F Motherboard;
MSI 945P Neo2-F Motherboard;
MSI 945P Platinum Motherboard;
MSI 955X Platinum Motherboard;
MSI 975X Platinum Motherboard;
MSI K9A Platinum Motherboard;
MSI K9N Diamond Motherboard;
MSI K9N Platinum Motherboard;
MSI K9N SLI Motherboard;
MSI K9N SLI Platinum Motherboard;
MSI K9N Ultra Motherboard;
MSI K9NGM Motherboard;
MSI K9NGM2 Motherboard;
MSI K9NU Neo Motherboard;
MSI K9SGM Motherboard;
MSI K9VGM Motherboard;
MSI P4N Diamond Motherboard;
MSI P4N SLI Motherboard;
MSI P4N SLI-FI Motherboard;
Shuttle XPC SN27P2.
- Kingston ValueRAM - DDR2 - module - 2 GB - DIMM 240-pin - 667 MHz / PC2-5300 - unbuffered
- Product Type
- Memory module
- Capacity
- 2 GB
- Memory Type
- DDR2 SDRAM - DIMM 240-pin
- Upgrade Type
- Generic
- Data Integrity Check
- Non-ECC
- Speed
- 667 MHz (PC2-5300)
- Latency Timings
- CL5
- Unbuffered
- Voltage
- 1.8 V
- Lead Plating
- Gold
- Limited lifetime warranty (Germany, Austria and France - 10 years)
- Capacity
- 2 GB
- Upgrade Type
- Generic
- DRAM memory module
- Technology
- DDR2 SDRAM
- Form Factor
- DIMM 240-pin
- Speed
- Latency Timings
- CL5
- Non-ECC
- Unbuffered
- Module Configuration
- 256 x 64
- Chips Organization
- 128 x 8
- Voltage
- 1.8 V
- Lead Plating
- Gold
- Compatible Slots
- 1 x memory - DIMM 240-pin
