Kingston ValueRAM 1GB 667MHz DDR2 Non-ECC
Quicklinx: 4NW2WS00 Mfr#: KVR667D2S5/1G
ValueRAM is Kingston's value-priced line of industry-standard, generic memory intended for customers who have white box or generic computer systems, or who plan to purchase memory by specification. ValueRAM is designed to industry specifications tested, is 100% tested and is available at competitively low prices.
Kingston ValueRAM - DDR2 - module - 1 GB - SO-DIMM 200-pin - 667 MHz / PC2-5300 - unbuffered
Memory module
1 GB
Memory Type
DDR2 SDRAM - SO-DIMM 200-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
667 MHz (PC2-5300)
Latency Timings
CL5
Unbuffered
Voltage
1.8 V
Lead Plating
Gold
Limited lifetime warranty (Germany, Austria and France - 10 years)
1 GB
Upgrade Type
Generic
DRAM memory module
DDR2 SDRAM
SO-DIMM 200-pin
Module Height (inch)
1.18
Speed
667 MHz (PC2-5300)
Latency Timings
CL5
Non-ECC
Unbuffered
Module Configuration
128 x 64
Chips Organization
64 x 8
Voltage
1.8 V
Lead Plating
Gold
Compatible Slots
1 x memory - SO-DIMM 200-pin
