Wait less, do more
The perfect companion for the avid photographer, videographer, design studios or printing houses, the USB 3.0 Media Reader is compatible with all major media cards types. As card capacities and file sizes increase, there is an increasing need to get your images transferred faster.
Rely on Kingston's USB 3.0 Media Reader to quickly move data between multiple devices. Use it at home or on the road; its convenient size makes it ultra-portable.
USB 3.0 offers the same ease of use and plug-and-play capabilities as previous generations of USB technologies but with a performance increase (up to 10 times faster than USB 2.0) and better power management. This USB 3.0 Media Reader is backwards compatible with USB 2.0.
The USB 3.0 Media Reader is backed by a two-year warranty and legendary Kingston® reliability.
- USB 3.0 -- up to 5.0Gb/s data transfer speed
- Ultra portable; sleek metal construction
- Maximise the full speed potential of your memory cards
FEATURES
- Built-in LED indicator and three-foot USB 3.0 cable
- Portable -- convenient small size
- Versatile -- works with the following Flash card formats:
CompactFlash (CF Type I (UDMA 0-6) , CF Type II (UDMA 0-6) )
Secure Digital ( SD , SDHC , SDHC UHS-I , SDXC , SDXC UHS-I )
microSD ( microSD , microSDHC , microSDXC , Memory Stick/M2 , Memory Stick , Memory Stick PRO , Memory Stick Duo , Memory Stick PRO Duo , Memory Stick M2 )
- Requirements -- system with USB 3.0 port
- Backwards compatible -- with USB 2.0
Versatile compatibility
Designed to meet the needs of various users, the Kingston USB 3.0 Media Reader supports a wide range of memory cards including CompactFlash, Memory Stick variants, SD, SDHC, and SDXC cards, making it an ideal solution for photographers, videographers, and other multimedia professionals. -
High-speed data transfer
Equipped with a USB 3.0 interface, this external card reader offers fast data transfer speeds, enhancing productivity and efficiency when transferring high-resolution images, video files, and other data-intensive content. -
Convenient design
The integrated USB cable and status indicator provide ease of use and real-time status updates, ensuring a seamless data transfer experience without the need for additional cables or software.
- Kingston USB 3.0 Media Reader - card reader - USB 3.0
- Product Type
- Card reader - external
- Supported Memory Cards
- CompactFlash Card type I, CompactFlash Card type II, Memory Stick, Memory Stick PRO, SD Memory Card, Memory Stick Duo, Memory Stick PRO Duo, microSD, SDHC Memory Card, Memory Stick Micro (M2), microSDHC, SDXC Memory Card, microSDXC, SDHC UHS-I Memory Card, SDXC UHS-I Memory Card
- Host Interface
- USB 3.0
- Status indicator, integrated USB cable
- 2-year warranty
- Product Type
- Host Interface
- USB 3.0
- 9.3 cm
- 5.3 cm
- 1.6 cm
Memory Card
- Capacity
- (max)
- Required Ports
- 1 x 9 pin USB Type A
- OS Required
- Microsoft Windows 7, Microsoft Windows Vista SP2, Microsoft Windows Vista SP1, Microsoft Windows XP SP3
- Limited warranty - 2 years
