Kingston's SSD installation kit contains all the necessary components for a quick system upgrade making switching to an SSD easy and affordable (drive sold separately).
With accessories such as a 2.5" USB enclosure, 7mm-9.5mm adapter frame, 3.5" mounting plate & screws, SATA power & data cables, cloning software and installation video, it is suitable for both notebook and desktop PCs.
Kingston's SSD installation kit is backed by a three-year warranty, free technical support and legendary Kingston(r) reliability.
- Kingston SSD Installation Kit - storage enclosure - SATA 3Gb/s - USB 2.0
- Storage enclosure - external
- Bus Type
- USB 2.0
- Expansion Bays
- 1 2.5"
- Hard Drive Form Factor Compatibility
- 2.5"
- Interface
- SATA 3Gb/s
- Data Transfer Rate
- 3 Gbit/s
- Supported Devices
- Hard drive, solid state drive
- Max Storage Devices Qty
- 1
- System Requirements
- Microsoft Windows Vista SP2, Microsoft Windows Vista SP1, Microsoft Windows XP SP3, Microsoft Windows 7 SP1
- 2.5"
- Host Bus
- USB 2.0
Storage Controller
- Interface
- SATA 3Gb/s
- 3 Gbit/s
- Supported Devices
- 1
- Bays
- 1 2.5"
- 1 x SATA 3Gb/s
- Connections
- 1 x USB 2.0
- Included Accessories
- 3.5" bay adapter, 2.5mm mounting spacer
- Cables Included
- 1 x power 15 pin SATA to 4 pin adapter - external , 1 x Serial ATA cable - external , 1 x USB cable - external
- Mounting Kit
- Included
- Software Included
- Drivers & Utilities
- OS Required
