Kingston's MobileLite Wireless G3 charges smartphones and tablets faster and charges phones up to 2x from a single, fully charged MLWG3. It lets you wirelessly access the contents of a USB drive or SD card. Free up space, make backup copies of important photos, videos, contact and calendar entries and transfer files to a new phone or tablet without using a PC.
Versatile compatibility
The Kingston MobileLite Wireless G3 offers broad compatibility across multiple devices, including Android, Apple iOS, and PC platforms, ensuring seamless connectivity for a wide range of users. -
Comprehensive connectivity
Featuring a variety of connectors including 4-pin USB Type-A, 5-pin Micro-USB Type-B, and RJ-45 network interface, this device provides extensive connectivity options to meet all your data transfer and streaming needs. -
Enhanced wireless performance
With support for the IEEE 802.11ac wireless standard alongside 802.11b/g/n, the MobileLite Wireless G3 delivers fast and reliable wireless connectivity, enabling efficient data streaming and file transfers. -
Powerful battery integration
Equipped with a built-in rechargeable 5400 mAh lithium-ion battery, this device not only supports extended usage periods but also doubles as a USB charger, adding convenience to its multifunctional capabilities. -
Durable and reliable
Adhering to ISO 9001 and SGS standards, the Kingston MobileLite Wireless G3 stands out for its durability and reliability, ensuring a high-quality experience for all users.
- Kingston MobileLite Wireless G3 - network media streaming adapter - USB
- Network media streaming adapter
- Form Factor
- External
- Interface (Bus) Type
- USB
- 11.5 cm x 8 cm x 2.4 cm
- 192 g
- Localisation
- Eastern Europe, EMEA
- Data Link Protocol
- 10Mb LAN, USB, 100Mb LAN, 802.11ac
- Frequency Band
- 2.4 GHz, 5 GHz
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- System Requirements
- Apple iOS 7 or later, Android 4.2 (Jelly Bean) or later
- 2-year warranty
- Form Factor
- External
- USB
- Localisation
- Connectivity Technology
- Wireless
- Ethernet, USB, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz, 5 GHz
- Status Indicators
- Wireless, battery
- Access Point operational mode, USB charger, built-in rechargeable 5400 mAh lithium ion battery
Processor / Memory
- Supported Memory Cards
- SD Memory Card, SDXC Memory Card, SDHC Memory Card
- 1 x USB - 4 pin USB Type A , 1 x USB - 5 pin Micro-USB Type B , 1 x network - RJ-45
- Included Accessories
- MicroSD adapter
- Cables Included
- 1 x micro-USB to USB cable (external)
- ISO 9001, SGS
- OS Required
- 11.5 cm
- 8 cm
- 2.4 cm
- 192 g
- Limited warranty - 2 years
- 0 °C
- 35 °C
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £3.67 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £9.84 |
