Kingston MobileLite G2 USB Card Reader
Quicklinx: 7MBWWS00 Mfr#: FCR-MLG2
Kingston's MobileLiteG2 is a compact, portable, multifunctional card reader that lets you easily transfer digital data, photos, games, music and more stored on memory expansion cards between all kinds of digital devices.
Designed for use with different types of SD/SDHC and microSD/SDHC Flash memory cards, MobileLiteG2 lets users carry a single device to store, transfer or read data on any USB host device while using a variety of flash cards for mobile phones, digital cameras, Netbooks, computers, MP3 players and more.
Ideal for personal or professional use, MobileLiteG2 will quickly become an essential part of your mobile gear. It's ultra-portable, plug and play and requires no external power source.
MobileLiteG2 has retractable covers on each side to make it compact and protect the USB connector and the Flash memory cards from damage. It includes a dongle, a USB extension that allows you to plug the MobileLiteG2 into USB slots that are harder to reach. When in use, MobileLiteG2 appears as two drive letters and data transfer is as simple as drag and drop.
  • Compliant
    With the Hi-Speed USB 2.0 specification, USB storage Class V1.0, SD 2.00, SDHC 4.1 standards, MS PRO-HG DUO standard, Universal Serial Bus specification revision 2.0.
  • Versatile
    Multifunctional USB card reader supports SD/SDHC, microSD/SDHC, MSPD, MS Pro HG Duo and M2.
  • Portable
    Easily fits in your pocket.
  • Easy
    Plug and play into any USB 2.0 or 1.1 port.
Kingston MobileLiteG2 card reader - USB 2.0
Card reader - external
Supported Memory Cards
SD Memory Card, Memory Stick PRO Duo, microSD, SDHC Memory Card, Memory Stick Micro (M2), microSDHC, Memory Stick PRO-HG Duo
Host Interface
USB 2.0
Host Interface
USB 2.0
62.3 mm
29.4 mm
16.4 mm
Memory Card
(max)
Required Ports
1 x 4 pin USB Type A
Microsoft Windows 2000 SP4, Microsoft Windows XP SP1 or later, Microsoft Windows 7, Apple MacOS X 10.3.x or later, Microsoft Windows Vista SP2, Linux 2.6 or later, Microsoft Windows Vista SP1
Plug and Play
