Kingston MobileLite Duo 3C microSD Reader - USB 3.1 Type-C / Type-A
Quicklinx: D0STWS00 Mfr#: FCR-ML3C
£7.15 ex VAT
£8.58 inc VAT
Kingston's MobileLite Duo 3C is a microSD card reader that works well with the latest products with USB Type-C ports, as well as devices that use USB Type-A. This versatile device has a small metallic form factor so it easily fits in a pocket, handbag or backpack and is ideal for personal or professional use. Offload files and photos quicker using the USB Type-C port, which has a universal connector that plugs in easily. This versatile device reads microSD/ SDHC/SDXC, UHS-I and supports the latest card speeds.
MobileLite Duo 3C is compliant with the USB 3.1 Gen 11 (USB 3.0) specification and delivers incredible performance to save time when transferring videos, photos and other large file sizes. It is backwards compatible with USB 2.0 ports to allow users to migrate to USB 3.0 in the future, using one card reader. MobileLite Duo 3C is backed by a two-year warranty, free technical support and legendary Kingston reliability.
  • Versatile compatibility
    The Kingston MobileLite Duo 3C card reader offers broad compatibility, supporting microSD, microSDHC UHS-I, and microSDXC UHS-I memory cards. This feature ensures users can effortlessly access, transfer, and backup data across a wide range of memory card formats.
  • High-speed connectivity
    Equipped with USB 3.1 Gen 1 interface, the Duo 3C facilitates fast data transfer rates, making it an efficient tool for managing and transferring large files, photos, and videos between devices without the wait.
Kingston MobileLite Duo 3C - card reader - USB 3.1 Gen 1
Card reader - external
Supported Memory Cards
microSD, microSDHC UHS-I Memory Card, microSDXC UHS-I Memory Card
Host Interface
USB 3.1 Gen 1
Apple MacBook Air (Late 2018); MacBook Pro (Late 2016, Mid 2017, Mid 2018)
Host Interface
USB 3.1 Gen 1
43 cm
18 cm
11 cm
Memory Card
(max)
Required Ports
1 x 9 pin USB Type A , 1 x 24 pin USB-C
Linux 2.6.x or later, Microsoft Windows 7 SP1, Google Chrome OS, Windows 8, Windows 8.1, Windows 10, Apple MacOS X 10.9.x or later
Apple MacBook Air (Late 2018) , Apple MacBook Pro (Late 2016, Mid 2017, Mid 2018)
Supported Formats: microSD
Supported Formats: microSDXC UHS-I Memory Card
Supported Formats: microSDHC UHS-I Memory Card
Interface: USB 3.1 Gen 1
Brand: Kingston
