Kingston KTC USB 3.0 Hi-Speed Media Reader
Quicklinx: CGX1WS00 Mfr#: FCR-HS4
£15.36 ex VAT
£18.43 inc VAT
Kingston's USB 3.0 High-Speed Media Reader reads all major card format types and supports UHS-I and UHS-II SD card speeds, making it ideal for photographers, videographers, design studios and printing houses. This versatile reader easily backs up photos and videos from your camera and lets you easily transfer photos, videos, music and other data between your favourite cards and your PC.
To maximize the performance of your memory cards and save time when transferring files, it features USB 3.0 high-speed performance with up to 5.0Gb/s data transfer speed, up to 10 times faster than USB 2.0.
The USB 3.0 media reader has a sleek design, with a white body and brushed nickel case in a small form factor, and an easily read, built-in LED indicator. It's backwards compatible with USB 2.0 ports, which is convenient for systems with limited USB 3.0 ports. For peace of mind, it's covered by a two-year warranty, free technical support and legendary Kingston reliability.
Kingston High-Speed Media Reader - card reader - USB 3.0
Card reader - external
Supported Memory Cards
CompactFlash Card type I, CompactFlash Card type II, Memory Stick, Memory Stick PRO, SD Memory Card, Memory Stick Duo, Memory Stick PRO Duo, CompactFlash Card, microSD, SDHC Memory Card, microSDHC, Memory Stick PRO-HG Duo, SDHC UHS-I Memory Card, SDXC UHS-I Memory Card, microSDHC UHS-I Memory Card, microSDXC UHS-I Memory Card
Host Interface
USB 3.0
White, brushed nickel
Status indicator, integrated USB cable
Host Interface
USB 3.0
9.33 cm
5.268 cm
1.6 cm
Memory Card
(max)
Required Ports
1 x 9 pin USB Type A
Microsoft Windows Vista SP2, Linux 2.6 or later, Microsoft Windows 7 SP1, Google Chrome OS, Apple MacOS X 10.7 or later, Windows 8, Windows 8.1
ISO 9001:2008, SGS
Supported Formats: CompactFlash Card
Supported Formats: Memory Stick PRO-HG Duo
Supported Formats: CompactFlash Card type II
Supported Formats: microSDHC
Supported Formats: Memory Stick Duo
Supported Formats: Memory Stick PRO Duo
Supported Formats: SD Memory Card
Supported Formats: SDHC Memory Card
Supported Formats: SDXC UHS-I Memory Card
Supported Formats: microSDHC UHS-I Memory Card
Supported Formats: microSDXC UHS-I Memory Card
Supported Formats: SDHC UHS-I Memory Card
Interface: USB 3.0
Brand: Kingston
