Kingston KTC 8GB DDR4 2133MHz SODIMM Module
Quicklinx: BZK1WS00 Mfr#: KCP421SS8/8
Kingston Technology offers extremely reliable, high-performance notebook memory. Every module is customised and tested to meet the exact specification requirements of each system. Kingston memory can increase the processing power of your notebook. It’s guaranteed to be compatible and offers a great cost-performance benefit plus better multitasking, faster processing of multimedia files and smoother video streaming. For added peace of mind, Kingston memory is backed by a lifetime warranty, free technical support and legendary Kingston reliability.
  • Expertise - From the industry leader in PC memory
  • Superior quality and testing - All components are qualified and all modules are tested at all stages of production.
  • Guaranteed compatibility - Kingston memory is guaranteed to be compatible with the system for which it’s designed.
  • Lifetime warranty and free technical support
  • Kingston system-specific memory for Acer, Apple (iMac, Mac mini, MacBook Pro), Dell, Fujitsu, Gateway, HP, Lenovo, LG Electronics, Medion, NEC, Samsung, Sony and Toshiba notebooks (please make sure to always check the system and memory compatibility).
Kingston - DDR4 - module - 8 GB - SO-DIMM 260-pin - 2133 MHz / PC4-17000 - unbuffered
Memory module
8 GB
Memory Type
DDR4 SDRAM - SO-DIMM 260-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2133 MHz (PC4-17000)
Latency Timings
CL15
Unbuffered
Voltage
1.2 V
Lead Plating
Gold
Limited lifetime warranty (Russia - 10 years)
8 GB
Upgrade Type
Generic
DRAM memory module
DDR4 SDRAM
SO-DIMM 260-pin
Speed
Latency Timings
CL15
Non-ECC
Unbuffered
Module Configuration
1024 x 64
Voltage
1.2 V
Lead Plating
Gold
