Kingston KTC 8GB 1333MHz Module
Quicklinx: BW0PWS00 Mfr#: KFJ9900E/8G
Kingston - DDR3 - module - 8 GB - DIMM 240-pin - 1333 MHz / PC3-10600 - unbuffered
Memory module
8 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
1333 MHz (PC3-10600)
Unbuffered
Fujitsu Celsius C620, M470, M470-2, M470-2 PREMIUM selection; PRIMERGY BX924 S4, RX100 S7, RX200 S8, RX300 S8, RX350 S8, TX100 S3, TX120 S3, TX140 S1
8 GB
Upgrade Type
System specific
DRAM memory module
DDR3 SDRAM
DIMM 240-pin
Speed
ECC
Unbuffered
Compatible Slots
1 x memory - DIMM 240-pin
Fujitsu Celsius C620, M470, M470-2, M470-2 PREMIUM selection , Fujitsu PRIMERGY BX924 S4, RX100 S7, RX200 S8, RX300 S8, RX350 S8, TX100 S3, TX120 S3, TX140 S1
