Kingston KTC 2TB NV1 M.2 2280 NVMe SSD
Quicklinx: GJYXWS00 Mfr#: SNVS/2000G
Kingston's NV1 NVMe PCIe SSD is a substantial storage solution that offers read/write speeds up to 2100/1700MB/s, which is 3 to 4 times faster than a SATA-based SSD, and 35 times faster than a traditional hard drive. NV1 works with lower power, lower heat, and quicker loading time. The efficient performance and single-sided M.2 2280 (22x80mm) design make NV1 ideal for thin notebooks and systems with limited space.
  • Robust durability
    Designed to withstand the rigors of daily use, this solid state drive offers shock and vibration tolerance that ensures reliability in various operating conditions. With vibration acceleration operating at 2.17 g and non-operating at 20 g, along with a wide frequency range, your data remains safe even in challenging environments.
  • High-speed performance
    Experience fast data transfer speeds with an internal data rate of up to 2100 MBps for reading and 1700 MBps for writing. The integration of PCI Express 3.0 x4 (NVMe) interface maximizes bandwidth, making it suitable for intensive applications and multitasking.
  • Efficient power management
    Optimized for efficiency, this SSD features low power consumption design with idle mode requiring only 5 mW. Average, read, and write modes are equally efficient, ensuring extended battery life for mobile devices and greener operation for desktops.
Kingston - SSD - 2 TB - PCIe 3.0 x4 (NVMe)
Solid state drive - internal
2 TB
M.2 2280
PCIe 3.0 x4 (NVMe)
NVM Express (NVMe)
22 mm x 80 mm x 2.1 mm
7 g
3-year warranty
2 TB
M.2 2280
PCIe 3.0 x4 (NVMe)
NVM Express (NVMe)
22 mm
80 mm
2.1 mm
7 g
Performance
SSD Endurance
480 TB
Internal Data Rate
2100 MBps (read) / 1700 MBps (write)
Expansion & Connectivity
1 x PCI Express 3.0 x4 (NVMe) - M.2 Card
Compatible Bay
M.2 2280
Power Consumption
5 mW (idle) , 340 mW (average) , 1.1 Watt (read) , 3.3 Watt (write)
Limited warranty - 3 years
70 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
85 °C
Vibration Tolerance (operating)
2.17 g @ 7-800 Hz
Vibration Tolerance (non-operating)
20 g @ 20-1000 Hz
